Results 1 to 18 of 18
    Nov 30 2014
    Dallas, TX
    JHM Spacers - NEED HELP URGENTLY!
    Hey guys,
    So yesterday I started working on my car, my intentions were to install JHM intake spacers, and replace the intake manifold cover since mine was flaking paint badly. So I removed the intake manifold, replaced the cover and applied black RTV to make a gasket, I installed the JHM spacers and put everything back together, started her up and low and behold, had a ton of problems!
    It sounds like there is air rushing in to both sides of the intake manifold, even though I torqued the screws down to 8 lb-ft like the video instructions said to. I checked and it looks like I re-installed everything correctly, no unhooked vacuum lines or anything. Has anyone else had this problem?
    I will say this, the 2 sets of gaskets they supplied are slightly embossed around where the 8 intake ports are, and I place these facing upwards, I suspect that is what I did wrong so today I am going to take her apart again and switch them. If this doesn't fix the problem I am going to pull out the spacers altogether.
    Any advice would be much appreciated!!
    Veteran Member Three Rings SprintBlueWorld's Avatar
    Sep 16 2013
    08 Hemi Big Horn, 08 Honda civic, 08 Audi S4 Cab MT6
    Pa
    RTV? There's no need for RTV in that job, it's gaskets only. As I recall the gaskets can really only go on one way. When you look at them the intake bolt down runner holes should fit flush with the spacer runner and bolt down holes. And each spacer should be sandwiched by gaskets.
    Vacuum problems can be a dime a dozen on this job. Check check and recheck. It's possible something looks together but it's not, such as a MAF hose. When I did mine it was not fully seated, leaving a hard to see thin gap, but affected how the car ran completely.
    Oem RS4 Reps, RS4 Pedals, KN Air Filter, JHM 93 tune, JHM Intake Spacers, Rear Stoptech Slots & SS Brake lines, JHM 6-Rib Pullys, 034 Snubby Bracket, Dimple/ECS Oil & Diff Magnetic Drain plugs, Apikol Diff Mount, 034 Carrier Mount Inserts, Corsa RSC Cat-Back, 034 Sway Bar & End Links, Piggies in a Blanket, Front JHM LW Rotors, Hawk HPS pads, 13mm Spacers
    Nov 30 2014
    Dallas, TX
    Quote Originally Posted by SprintBlueWorld View Post
    There's a gasket in there when I took the intake manifold apart, I undid the torx screws and separated the top and bottom parts, the gasket in there fell apart so I had to make one with black gasket making material (high temp RTV).
    I'm rewatching the JHM video right now, I think I made a mistake while installing the spacers, I will double check that they're seated down correctly and I'll thoroughly clean the area again before putting the first gasket down, I hope I didn't miss some dirt or something down there that is causing the gasket to not quote sit down properly.
    I'll be tearing her apart in another hour so so.
    Sep 16 2013
    Pa
    Ahh that is a sensible application of RTV.
    Good luck!
    Nov 30 2014
    Dallas, TX
    God I feel so stupid.
    It turned out to be 2 injectors that were missing O-rings. When I pulled the fuel rail up I guess 2 O-rings got left behind in the intake manifold cover, and since I swapped this part, there wasn't a good seal and air was getting sucked into the system and causing it to idle rough. Got it fixed temporarily but I am going to have to order fresh O-rings just to be safe and I will have to find a way to replace the little red retaining clips that go on the injector to keep the O-rings in place because a few of mine broke.
    Nov 30 2014
    Dallas, TX
    In case anyone has a similar problem, here is the solution:
    https://jhmotorsports.com/shop/catal...-s4-p-630.html
    Going to order 8 and replace all of mine, the OEM config is too flimsy, I'm surprised a plastic pintle cap hasn't broken and fallen into the intake port.
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    glad you got it figured out... been there and done that, was just fixing to post check your o-rings ;)
    PAST
    2004 Audi (B6) S4 4.2L
    2006 Audi (B7) S4 4.2L 25th Anniversary Special Edition #167
    Current
    2015 Audi (B8.5) A4 2.0T P+ Sline ECS-Luft-Technik Intake System/Air Scoop v2/Silicone Intake Tract Set with turbo muffler delete, GFB DV+ VTA Performance Blow-Off Valve, JHM FMIC/ECU and TCU (Automatic 8 Tip Quattro) Stage 2 tunes. Cosmetic RS4 Honeycomb Mesh Front Grille and Fog Light Vent Grilles
    Feb 18 2014
    Arizona
    ya, the pintle caps are pretty common to break. I doubt anyone has pulled the ruel rail after more than 100k miles on the original pintle caps without breaking a few of them
    Veteran Member Three Rings jmcS4's Avatar
    Nov 16 2013
    q7 tdi+, b5 s4, r56 mcs
    Lower NH
    Quote Originally Posted by gautam View Post
    i did this a couple weeks ago. when i removed my fuel rail a o ring decided it wasn't coming out. so when i installed it the injector didn't seat and i ended up with a misfire and rushing air sound lol
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    >12' Q7 TDI S-Line Plus
    >R56 Mini S w/jcw aero kit
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    Quote Originally Posted by 2004B6S4 View Post
    I've pulled my fuel rail at least a dozen times since 100k and I've yet to replace a single pintle cap or o-ring.
    It's fun because the first job I did that required moving the IM I bought a bunch of both as spares since everyone says they break. Still have that bag of parts in the cabinet somewhere... I do clean them and relube the orings nearly every time though
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Nov 30 2014
    Dallas, TX
    Oh man I was so relieved, I thought I'd have to tow it to the shop and get professional help haha thank god it turned out to be something cheap and simple to fix.
    My car is out of commission for a few days though till JHM ships me new pintle caps. I bought 12 of them and the shipping cost more than the parts haha. I also bought the fuel injector installation kit from ECS and it should get here around the same time as the pintle caps. Going to replace all the O-rings and retaining clips while I have the fuel rail off.
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Glad you got this sorted!
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    hmm, guess i should order some to be safe, what is the part numbers for that, your link wouldn't show for me. or part name.
    found the pintle caps, just need to find the orings, and I cannot find them on the site at all.
    https://jhmotorsports.com/shop/catal...-s4-p-630.html Injector pintle caps x8
    Aug 31 2011
    Lathrop
    Quote Originally Posted by Terry.Reese View Post
    https://jhmotorsports.com/shop/catal...fsi-p-412.html
    Oct 05 2015
    Billings, MT
    Thanks Jake!!
    Veteran Member Three Rings Brettannica's Avatar
    Oct 14 2012
    2010 Audi A4 Avant
    Perth, Western Australia
    I have a heap of o-rings you can have if you want to pick them up.
    Oh, BTW, I’m in Australia.
    In The Garage: B7 S4: JHM Tune Carbon Fibre: Vis Racing Hood, Relak Skirts & Paddle Extensions, Blades, DTM Deck Lip : 034 Snub & Bracket : JR Air Filter : H&R Springs : F.I. Catback : Gunmetal 19” 6RS V10’s • B8 A4 Avant: BSR Bling : 19” 4RS V10’s : V-Tech Chip
    Previous Rides: • E32 BMW 740i • E36 BMW 325i • B5 A3S • B6 A4 • Ford Falcon 351 • Triumph TR8 • Vauxall Super Tourer • Saab 9-3 • Saab 9-5 • Toyota Prado 4x4
    Nov 30 2014
    Dallas, TX
    This is what I ordered:
    https://www.ecstuning.com/ES2593910/
    Going to replace all 16 O-rings, 8 pintle caps (got 12 new ones from JHM), 8 retaining clips, and I'll keep the bolts as spares. The bolts currently on my car don't have washers so I'll put the washers in. Also, the holes they go in to got busted on the right side so I ordered a helicoil kit from ECS and I am going to install helicoils in all 4 holes.
    Oct 05 2015
    Billings, MT
    got the Pintle mounts from JHM and the install kit from ECS, so now just waiting for them so I can start on fixing mine.
