Results 1 to 10 of 10
    Established Member Two Rings cloaked's Avatar
    Jun 11 2008
    West Hollywood
    Amber rear light
    I got out of my car and walked to the rear hatch there I discovered an amber diagonal light only on the driver's side, strange I had no indicators pointing to a light issue. I was told that it is a Euro lamp setting for fog. The bulb was removed because the code to turn on both rear amber tail lights wasn't available. I personally like having the amber light in addition to the standard lights. Does anyone have a recommended location in Southern Cal area to program the tail lights to Euro spec.
    Jul 17 2011
    Sin City, USA
    Post up in the SoCal regional thread so you can get people local to you responding. Better chances!
    '09 C6.5 A6
    Senior Member Three Rings skylinrcr01's Avatar
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    Eurocode in torrance may be able to help, they are more or less the local LA audi shop. Otherwise, pacific german in Laguna Hills, but it's gonna be a hike from WeHo.
    http://i.imgur.com/KPi8p89.jpg
    2004 Mercedes E55 AMG
    2005 A6 Quattro 3.2 (Sold)
    2005 BMW K1200S
    Jun 11 2008
    West Hollywood
    Cool thanks for the reply enthusiast.
    Aug 31 2014
    BMW K1200S
    Orange County, Ca
    Np. :)
    2005 BMW K1200S
    Senior Member Two Rings se.farrell's Avatar
    Jan 10 2014
    Los Angeles, CA
    X2 for Eurocode. - higher price(for an indy), but great work.
    If M-F is not an option then you can head down to AUTuning in Newport. Been there, would recommend, work on (almost exclusively) on VAG cars, slightly cheaper than Eurocode.
    Current:
    C7 A6 3.0T Prestige - Glacier White
    STAGE 1 | TSW
    C6 A6 S-line - GONE
    Jun 11 2008
    West Hollywood
    Quote Originally Posted by se.farrell View Post
    Thanks for the heads up. I contacted Eurocode, it can be done, but it requires some additional tweaking because the right side wasn't setup for an amber, which is just a light that's activated when the car is parked on the side of a road a Euro thing, I saw it on a P 924 a friend had back in the day.
    Active Member Two Rings Flad.Solo.View's Avatar
    Mar 07 2012
    Ukraine, Kiev
    Quote Originally Posted by cloaked View Post
    do you have a vag com cable?
    you can change the coding by yourself
    — [46 — Comfort System];
    — [Coding — 07];
    minus 0004096 from your current value
    it would be a Euro specs with amber turn signals, LED stops, one reverse and one rear fog light
    Jun 11 2008
    West Hollywood
    Quote Originally Posted by Flad.Solo.View View Post
    — [Coding — 07];
    Thanks I'll send thist info to my mechanic and let him play with it to see if I can get both rear ambers operational
    Mar 07 2012
    Ukraine, Kiev
    ok, its easy process, you just need vag com cable and laptop.
    few days ago i've made + 0004096 to my current Euro rear lights, just for fun)
    Audi A6 C5 '03 1.8T AWT FWD
    Audi A6 C6 '07 2.4 BDW FWD
    Audi A6 C7 '16 2.0TFSI FWD
