Page 1 of 3 123 LastLast
Results 1 to 40 of 104
    Veteran Member Four Rings ntsantos's Avatar
    Dec 06 2015
    San Ramon, CA
    A7 and RS7 OEM Airbox
    Does anyone know if the oem RS7 Airbox will be a direct fit in an A7?
    I want the extra holes and the oem look it has without resorting to ghetto - engineering. I figure if the RS7 box can handle 560hp than it should flow well enough for my A7.
    Registered Member Three Rings DoughBoyFreshLV's Avatar
    Apr 02 2014
    Las Vegas, Nv
    Quote Originally Posted by ntsantos View Post
    That won't fit, they're 2 different engines, if you want a stock look them leave it stock and change your air filter to a k&n. If you want more holes, pull the air box out and drill holes in the bottom, you'll never see it and no one will ever know.
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    AKA: Yoshi123
    Veteran Member Three Rings Dguth's Avatar
    Dec 14 2011
    Dublin, OH
    Sorry misread post. A6 is different engine setup.
    2014 S6 | Glacier White | Prestige Package | B&O Sound | Tinted & Lowered | APR Stage 1.1 Tune | APR TCU Tune | XPEL Front | Flat Bottom Steering Wheel | Soon to be installed: RS7 Turbo, RS7 Intake, AMS Coolant Upgrade, AMS High Flow Downpipes, RS6 Grill and APR Stage 3 Tune
    Dec 06 2015
    San Ramon, CA
    Quote Originally Posted by Yoshi123 View Post
    I might try the holes at the bottom if the rs box doesn't fit.
    Just looking at the overall shapes and mounting locations, they look so damn similar other than the rs box has a flatter top (more volume). The intake hoses are definitely different but sent to enter the box at the same locations. It may be worth trying...look out for an rs7 Airbox on the classifieds soon!
    Dec 06 2015
    San Ramon, CA
    So I just answered my original question and yes, the rs7 box does fit the A7! I ordered the part from ECS, and used the 034 silicone throttle body hose and k&n filter. The box is 100% bolt with no modifications required. The 034 hose however is a little short, so I used a silicone adapter from pep boys.
    The beloved sc whine is definitely there thanks to the silicone hose and additional holes on the box. Butt dyno feels no different than the previous Injen intake I had, maybe a bit smoother.
    Overall I'm happy I did it. Very OEM+ look with aftermarket performance and sound. Not cheap by any means, it cost around $400 total for the hose and box, but I definitely got what I was after.
    Jan 30 2015
    2012 A6 3.0T Prestige + others
    Irvine/CA
    Nice
    Wonder if that works on A6 as well
    - Michael
    2012 A6 3.0T Prestige:
    GIAC Dual Pulley 57.1+187 / Merc HX / Injen Intake / OEM muffler mod (Quad Tips + X-Pipe) / Eurocode drivetrain inserts / 034 Swaybar / Volk wheels / Bilstein+Eibach / RS front grill / Deval Carbon rear diffuser / Maxton Front Spoiler and Side Skirt add on / Carbon trunk spoiler / Carbon mirror / Stoptech rotors.
    Dec 06 2015
    San Ramon, CA
    Quote Originally Posted by yeuchau View Post
    Nice
    If the A7 and A6 air box Audi part numbers match, then it should be a go.
    Veteran Member Three Rings kouzman's Avatar
    Nov 03 2014
    15 Audi RS7, 14 Audi A4 2.0T
    new york
    I can also suggest that you remove the plastic flap inside the box held by two Allen screws on the scoop side. It's there to probably reduce induction noise and to direct air over the filter I guess for redicing water exposure when raining. I would do that on mine since I rarely drive my car when raining...
    2015 Porsche 911 Turbo S
    Jan 30 2015
    Irvine/CA
    Is the A7 box part number 4G0 133 836R or 4G0 133 843?
    - Michael
    Dec 06 2015
    San Ramon, CA
    Here's a shot from the actual box.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Dec 06 2015
    San Ramon, CA
    Quote Originally Posted by kouzman View Post
    I was wondering what that was for. It makes sense that there's drain holes at the bottom of the box too.
    Jan 13 2017
    Nsx, A7
    Corona, ca
    Anyone have the info to this box so I can convert my a7 to rs7 intake?
    Oct 02 2005
    The Moon
    Funny to see this pop up as my parts guy just sent me this picture. Can't wait for it to show up next week.
    Jan 13 2017
    Nsx, A7
    Corona, ca
    Lol you again. Is there a video on converting it?
    Jan 13 2017
    Nsx, A7
    Corona, ca
    Quote Originally Posted by p3u View Post
    how are you going from 2 to 1 intake hose
    Dec 06 2015
    San Ramon, CA
    Quote Originally Posted by A7tdi View Post
    You throw that part away and use the one from the A6/7
    Sent from my SM-G930V using Tapatalk
    Jan 13 2017
    Nsx, A7
    Corona, ca
    they are removable?
    Dec 06 2015
    San Ramon, CA
    they are removable?
    You really need to take apart your stock intake assembly, then put it back together. Then you'll fully understand the parts and pieces. Otherwise, you'll be at the mercy of this forum. It truly is plug and play.
    Jan 13 2017
    Nsx, A7
    Corona, ca
    Ok sounds good. I'll get on it. I just bought the box. I called ecs but they didn't have the silicone hose. Do you have the item number?
    Oct 02 2005
    The Moon
    Oh boy! Lol, nah, but it's pretty straight forward. Is the throttle body the same size on the TDI for the hose to work?
    Jan 13 2017
    Nsx, A7
    Corona, ca
    Everything is the same. It should be able to get it done. Just didn't look like a removable piece but I guess it is. Mine should be here Friday I'll play with it. Haha.
    Dec 06 2015
    San Ramon, CA
    Its an 034 hose for a B8S4, i got it directly from 034. ECS sells it i think, but you need to shop for it in the B8 section. The hose is NOT plug and play. Just stick with the oem hose for now, youll be fine.
    Jan 13 2017
    Nsx, A7
    Corona, ca
    I know the hose is the main part but we shall see when I get it this week. Thanks man.
    Registered User Four Rings mike@ngp_racing's Avatar
    Oct 29 2014
    Aberdeen, MD
    We've just completed this swap for one of our A7 customers as we were installing an APR Ultracharger and some JHM and AWE loud parts. Installation is very straightforward and like mentioned above, you need to retain the A7 single-tube intake port/panel, and we also removed the small plastic bell/tube/stack inside the intake. I don't have any empirical data to support my feelings on its effectiveness, but throttle responsiveness does feel snappier than with a stock air box, and it does amplify the supercharger whine somewhat.
    Jan 13 2017
    Nsx, A7
    Corona, ca
    Quote Originally Posted by mike@ngp_racing View Post
    That looks great but wouldn't work on my TDI or will it. lol
    Apr 17 2017
    2016 Sequoia
    Kansas City Area - OP, KS
    Mike, did you use the stock air filter, or change that out as well?
    Oct 29 2014
    Aberdeen, MD
    Quote Originally Posted by Moodys2014a6 View Post
    We used the filter that accompanied the APR intake (K&N style cone filter).
    Jan 13 2017
    Nsx, A7
    Corona, ca
    QUOTE=ntsantos;12718148]Its an 034 hose for a B8S4, i got it directly from 034. ECS sells it i think, but you need to shop for it in the B8 section. The hose is NOT plug and play. Just stick with the oem hose for now, youll be fine.
    Sent from my SM-G930V using Tapatalk[/QUOTE]
    This is the hose right?
    Active Member Three Rings NASAudi's Avatar
    Nov 28 2016
    Chandler/Arizona/USA
    No. Because an RS7 is a twin turbo with 2 intakes. It won't match up on a 3.0t engine.
    NASAudi
    Oct 02 2005
    The Moon
    [[/QUOTE]
    That's the hose, but it has to be modified to work.
    Quote Originally Posted by NASAudi View Post
    NASAudi
    Incorrect, the nozzle is swapped out to the single tube from the A6 box for direct fit.
    Jan 13 2017
    Nsx, A7
    Corona, ca
    Oh ok the nsantos said its the b8 hose that he used from 034 this is that hose.
    Dec 06 2015
    San Ramon, CA
    That is the hose I used. But it has to be modified to fit. Since its for the B8, it will be too short. I added a 3x3.5" coupling.
    I have changed since then, and now I use the ECS carbon fiber tube, also for the B8S4. It will fit with a little tweaking.
    Jan 13 2017
    Nsx, A7
    Corona, ca
    Oh ok Thank you.
    Oct 02 2005
    The Moon
    What dat?
    Dec 06 2015
    San Ramon, CA
    What dat?
    Lol...it was for a small HX fan. I removed it since then.
    Jan 13 2017
    Nsx, A7
    Corona, ca
    So I was looking on their website and it shows it doesn't fit. Haha their site sucks ass. Do you know they item number?
    Oct 02 2005
    The Moon
    It's not going to show it fits an S6, it's for a B8 S4.
    Jan 13 2017
    Nsx, A7
    Corona, ca
    Well their site still sucks.
    Jan 13 2017
    Nsx, A7
    Corona, ca
    What intake is everyone running for that efficient power? K&n?
    Oct 02 2005
    The Moon
    I've found the best airflow comes from a well used and oiled sock. Has to be cotton though, none of that synthetic rayon shit.
