Results 1 to 21 of 21
    Senior Member Two Rings BumbleBee's Avatar
    Nov 09 2008
    Autobots
    Audi S5 4.2 V8 TFSI TEST PIPES CAT DELETE Pipes 100% OEM Fitment TIG Welded FREE SHIP
    $400 Shipped
    BEST QUALITY DIRECT FIT!!!
    BRAND NEW TEST PIPES * CAT DELETE * PIPES
    FIT S5 4.2 V8
    100% OEM FITMENT, UTALIZED FACTORY MOUNTS
    WILL FIT DSG OR MANUAL TRANSMISSION
    BETTER THROTTLE RESPONSE AND MORE TOP END
    TUNING ALSO AVAILABLE FOR THE 4.2 V8 TO UTALIZE THE TEST PIPES AND SHUT OFF THE CEL
    FREE SHIPPING
    MADE IN USA
    HIGH QUALITY T304 STAINLESS TIG WELDED
    Product Features & Benefits
    Designed and Manufactured in the USA
    T304 Stainless Steel materials
    Completely Tig welded
    63.5mm (20% increased diameter) Inlet and Outlet design (50.8mm on factory cats) match ported to utilize factory gaskets
    Reduces weight by 11lbs. (stock cats weigh in combined at 19.2lbs. Cat delete pipes weigh in combined at 8.2lbs.)
    Low profile design
    Mandrel Bends
    Laser CNC cut OEM style mounting flanges (No welding or cutting required)
    Designed to work with stock and most aftermarket stock mounting exhaust systems
    Direct fit
    Will add more sound to your exhaust note
    Reduced Exhaust Gas Temps
    "The least likely can be the most dangerous."
    2001 S4 GT28RS SSP Tuned
    2004 Audi RS6 SSP Tuned - 6 Speed Converted GT30's
    2006 Porsche 911 Turbo - SSP Tuned -
    2013 Audi S4 SSP Tuned
    2016 Audi S3 SSP Tuned
    May 18 2016
    Orlando
    Any drone? Do you have any sound clips?
    Dec 26 2008
    STL
    What about the back O2 sensors? Is this the same like JHM units?
    Installation info..?
    Nov 09 2008
    Autobots
    Quote Originally Posted by Slobo7x View Post
    similar to JHM units, there is a bung for rear o2, if you want to delete the rear o2 sensors i can turn them off in your ecu
    Active Member Two Rings bryantlopez631's Avatar
    Nov 20 2015
    2010 c300, 2015 Ram 2500
    Bay shore New York
    I've been looking to do this mod I have an auto will it still require the tranny removed for installation ?
    Nov 09 2008
    Autobots
    Quote Originally Posted by bryantlopez631 View Post
    No just remove secondary firewall and axles and axle shields to be able to install this.
    Nov 20 2015
    Bay shore New York
    Message me am interested in buying
    Dec 26 2008
    STL
    Quote Originally Posted by BumbleBee View Post
    Thank you. Sadly this is more help then JHM customer service was able to give on their own products. You would think once you make something for the market, you'd be able to provide some sort of instructions on the installation.
    I am pretty good with the wrench, but results are scattered all over whether the transmission has to come out or not to replace the test pipes.
    Thanks BumbleBee, that helps quite a bit.
    Nov 20 2015
    Bay shore New York
    Second to that ^ I've been on the edge of doing this because I though the tranny had to be removed now that I know it doesn't I'll be doing this mod
    Nov 09 2008
    Autobots
    BUMP :)
    Active Member Two Rings Mike586's Avatar
    Jul 24 2013
    Houston
    Still available?
    Sent from my SM-G925T using Audizine mobile app
    Nov 09 2008
    Autobots
    Quote Originally Posted by Mike586 View Post
    Still available?
    yes
    Nov 09 2008
    Autobots
    BUMP
    - - - Updated - - -
    STILL HAVE SOME
    Veteran Member Four Rings DreDay's Avatar
    Apr 25 2010
    Morris County, NJ
    Has anyone bought and installed these? Any feedback? Sound clips? Thanks!
    CURRENT| C7.5 A7 TDI [MODS INCOMMING!] + 958 Cayenne Turbo
    PAST| Bagged MK1 R8| B8 SQ5| B8 S5| B6 S4| B6 A4| C5 Allroad| (2) T2 Touareg V8| Gen 2 Cayenne S
    NEXT| Another Stance Project
    Jul 08 2014
    Cleveland, OH
    Agreed. I'm highly interested in these except I'd like some feedback from others regarding the fit-up.
    Nov 09 2008
    Autobots
    sold over 15 sets and never had any complaints with fitment, if you want pm me and i can give you some contacts to ask them
    Dec 09 2013
    United States
    still available? what brand are these ? or were if not available
    Senior Member Two Rings Lizard 1's Avatar
    Jan 26 2016
    Lots of fun stuff
    Gahanna, OH
    Probably a dumb question, but I have a Corsa system and wondered if these will bolt up? I assume they would if they replace OEM 100%, but want to ask.
    Junior Member Two Rings BJS5's Avatar
    Dec 26 2019
    Pittsburgh
    Is this still available?
    Veteran Member Three Rings volvofan's Avatar
    Sep 10 2016
    MA
    You absolutely do NOT have to completely remove the transmission (or axles) to do this mod, but I will tell you that, even with a drive-on lift, it takes a fair amount of work and time to get the stock cats off. You've got to loosen the front subframe and allow the transmission to sag considerably, carefully watching connected hoses & wiring to make sure you don't pinch or pull something. You need some LOOOOONG and flexible extensions to get onto those bolts around the big cat "coffee cans." Installation of test pipes is far easier than removal of stock pipes because you're not working around that can to get at the bolts. A "crow's foot" or "dog bone" adapter may make the removal job easier, but I didn't have one.
    My car has the APR RSC exhaust and it bolted right up. I cut in after the X-pipe and added Magnaflow high-flow 100 CPS cats as well as some additional resonators just before the mufflers because it was a bit too raspy and throaty for me... I have to keep this car civilized as it's my DD and the wife borrows it a lot, too. I LOOOOOOVE the sound, and with the APR intake, 034 Motorsports high-flow silicone TB hose, custom tune from M2 motorsports I freed up almost 40 AWHP over those same mods running on the stock tune. Yes, dyno-proven before & after. I'm not saying I don't miss my APR Stage III supercharger, BUT........... Ava's still pretty f-ing snappy and sounds the business, too.
    -Jon
    2013 RS5 Coupe 57k; slower than an Apache... not by much.
    GO - ECS intake; LWCP / LWFW / FP; Kline headers & exh; HFCs
    STOP - Forgestar F14s; Michelin Pilot Sport AS4; Voshmods rear BBK; CCBs x4
    TURN - ALL the braces; EuroCode sways; PowerFlex inserts; KW HAS; SPC UCAs
    PROTECT - RMR xmsn cooler / bar; ECS shields; JXB bearing; AG battery
    A/V - RSNav S4 10.25"; JL 8W1V3 sub; Alpine MRV-M500 amp; lighted sills/rings
    OTHER - Weathertech; Ziza LEDs; RMR hoses; ALL the carbon fiber
    Junior Member One Ring Benzin971's Avatar
    Sep 28 2023
    Toronto, Ontario, Canada
    A little late... still available?
    2008 S5 4.2L CAUA V8 bay-beee
