Results 1 to 9 of 9
    Active Member Two Rings Pkr1991's Avatar
    Oct 03 2015
    Massachusetts
    Getting rid of that mold smell when starting A/C
    I've been given multiple ideas but I honestly trust you guys more considering you all have the car. Easy advice on a quick way to fix this problem? I've been told lysol disinfectant spray will work just fine but before i go ahead and start spraying away I want to make sure its a good idea to do so and also where exactly should i spray? Never had to do this before so feel free to dumb it down for me.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Dec 25 2004
    Earth
    THE BEST Shiza around!
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Sep 15 2012
    Kingsland, GA
    Anyone have a pic of the condensate drain location? I can't seem to find mine.
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by fast377 View Post
    Clicky click®
    Sep 15 2012
    Kingsland, GA
    Thanks! Where does it exit under the car!
    Dec 28 2006
    Western Maryland
    This should help: Clicky click® It's for the Cabriolet but it's the same as the A4 sedan.
    Push a piece of weed wacker cord or anything else flexible through hole "E" and you will see where it exits from below the car.
    Here's another view of hole "E"
    Sep 15 2012
    Kingsland, GA
    Sweet, thank you sir!
    Aug 26 2005
    I have had excellent results using Lysol. Lysol treatment kills mold and mildew that grows in the A/C evaporator coil and evaporator drain pan, and deodorizes the A/C system.
    To apply Lysol, tape a paper towel loosely over each of the dash vents, then remove the cabin fresh air intake filter. Next, With the windows open and ign key ON, engine OFF, adjust the A/C to LOW temp, MAX fan speed. Then spray one whole can of Lysol into the cabin fresh air intake fan. When the Lysol can is empty, turn the A/C fan Off, ign key OFF, and remove the paper towels from the dash vents. Install a new cabin fresh air intake filter. Allow about 1 hour before operating the A/C/heater. Repeat as needed.
    Vorsprung durch Technik
