Results 1 to 6 of 6
    Established Member Two Rings daniel B6 1.8t's Avatar
    May 31 2016
    OC, CA
    exhaust system info needed...
    I live in cali any recommendations? 1.8t Quattro b6 ..... I hear borla system is good for it since it's a 1.8 and price is decent. Is it worth it? Or do i need to upgrade first the cat. Trying to get more flow for the turbo...stock haven't done anything just berry had it for 3months 90xxxmiles
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    You might want to post this in the A4 section.
    Old Geezer, formerly known as Stud Muffin
    Registered User Three Rings MagnaFlow's Avatar
    Jan 26 2015
    Oceanside, CA
    Daniel, the benefits of a quality catback exhaust system definitely make them worth the money. Our B6 1.8t exhaust system, #16601 will help improve your turbo response and flow more freely due to the larger diameter piping and straight-through-style mufflers. All of our products are manufactured right by you in orange county (oceanside to be exact), and come with a lifetime warranty against any defects. Modifying the cats and emission equipment is not recommended because it will effect your vehicles CARB-compliance. If there are any questions we can answer, please feel free to send us a PM!
    Jan 09 2013
    ___
    Quote Originally Posted by MagnaFlow View Post
    OP, just a heads up, don't fall for this if you're unfamiliar with exhaust systems. An exhaust without a tune does nothing for you, so go with whichever is in your budget and seems to be constructed well. This is a dyno chart of a B7 A4 2.0T (close enough) and it gained a whole 4hp!
    May 31 2016
    OC, CA
    Thanks tmh88 for the heads uo
    May 31 2016
    OC, CA
    I I'll just stick with borla then. And just upgrade the cat from magnaflow then.
