Results 1 to 6 of 6
    Veteran Member Four Rings MattboyR32's Avatar
    Nov 28 2006
    Orange County, CA, USA
    Aftermarket Seats
    Hey everyone, just want to clarify/confirm some of my research regarding install of aftermarket seats.
    - I don't need a pressure sensor or any other special sensor mods for the drivers side? Passenger side requires a occupancy sensor (or short circuit), but drivers side doesn't seem to require one. Is that because it's assumed you are always going to have a driver and the airbag is activated once you put the seat belt on?
    Is there anything else I need to know from an electrical point of view? Just want to make sure that the airbags will still work...
    cheers
    B7 RS4 6MT Daytona Grey
    JHM 2.75" catback non-res, piggie pipes, 034 transmission, engine mounts, strut mounts & end links, Apikol diff mount, Hotchkis adjustable rsb, Escort 9500i (HW), JHM lightweight rotors, JHM intake manifold spacers, BC Racing coilovers,
    RIP: B7 S4 DTM 6MT Dolphin Grey
    JHM Tune, Corsa Catback, Piggie Pipes, Bilstein PSS9, RS4 Reps, Blackvue Car Blackbox (HW), Escort 9500i (HW)
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    correct , just the passanger side has the pods system. there are however airbags in the stock seats which will cause an airbag light if removed. you may be able to code these out but not sure.
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Nov 28 2006
    Ok great.
    Anyone got any thoughts how to code out the seat airbags?
    I presume there must be a way since the Euro RS4s come with optional bucket seats that don't have the side airbags.
    Cheers
    Mar 08 2011
    union, nj
    I just had this done on the recaro sportsters and its done with resistors. Don't know what size though, if i find the info ill let you know.
    Nov 28 2006
    Quote Originally Posted by 08 classic View Post
    Awesome. Thanks.
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    You wont be able to code it out, gotta use resistors. I need to do it on my car to get rid of airbag light. I think ive read somewhere that resistors need to be 4,7 ohm but not sure.
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
