Results 1 to 22 of 22
    May 09 2012
    Virginia
    Fueling questions for Stage 3 setups
    All,
    I am running a GT2871r setup from AWE. I will be building the bottom end to be able to extract a bit more from the motor and turbo. I replaced the proprietary RS4 injectors from AWE with S3 injectors for several reasons. I am trying to identify the bottlenecks in the fueling system and whether or not they will be applicable to my hardware. I have an upgraded HPFP already (APR). Still have stock LPFP and stock controller. The other elements that I have seen people address are the PRV and fuel lines and rail.
    For those of you running similar or more robust setup's, can you comment on the fueling issues you encountered and what elements you addressed. Thanks.
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Definitely get an RS4 LPFP control module if you are running all that...
    Also the PRV 100%. Simple bolt ons that make a big difference....
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Mar 24 2013
    Oakdale, CT
    Your HPFP and S3 injectors should be fine for that turbo. If you are still running stock lpfp and controller, as well as the rail valve, that's where I would focus my upgrades. The RS4 rail valve should work fine since it has a lift pressure of 136 bar IIRC (you will likely be running a tune that requests 130 bar.) The stock lpfp could work if it isn't a tired original, but the stock controller tends to overheat and crap out when pushed too hard.
    -Adam
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    Like Aluthman said focus on the low side. The S3's and HPFP are fine. You should be able to get the s3's up to 500 with secondary fueling.
    The stock controller likes to over heat, so I would either replace it with a new unit and add torquebtye or just swap in a rs4 unit. The stock LPFP is pretty robust and can handle fueling but you are going to be pushing it close to its max in the future. If you want to run the stock LPFP APR does make a LPFP inline pump that can help supplement the fueling on the low side and you should be good up to 500 again on the low side.
    Rs4 PRV is plenty unless you want more fueling overhead for the injectors then go with HPFPupgrades.com custom 150Prv and above.
    I run a S3 K04 with S3 injectors, HPFP stage 2 pump, TTRS lpfp, stock lpfp(needs upgraded), and 155 PRV, but at the same time I am one of the only people running full E85 on my setup. I can tell you that I am hitting the limits of the stock LPFP controller and S3 injectors.
    2008 Audi A4 2.0T
    320awhp/420awtq...E85---UnitedMotorsports Tuned
    2015 A3 8v P-Stock
    2003 A4 Avant 3L-sold
    May 09 2012
    Virginia
    Thanks for the feedback all. Trying to get up to speed. Have read through the relevant build threads here and elsewhere. Trying to source the RS4 LPFP controller and will go with the PRV and go from there. I'll see how long the fuel pump lasts.
    Veteran Member Four Rings derrek's Avatar
    Jul 23 2010
    arizona
    If you really look at the whole fuel system you'll find the flaws and see what needs to be changed to reach your goals. I found way more then enough fuel to max out my old setup on e85. This platform has more fueling then everyone gives it credit for.
    Oct 24 2015
    Perth, WA
    Yeah, I would look for pressure drops before moving to more hardware where you may not need it.
    My respray thread
    Aug 05 2011
    CO
    Quote Originally Posted by derrek View Post
    Didn't you go pretty much the same route as me for fueling, minus the W/M that you use
    2008 Audi A4 2.0T
    2015 A3 8v P-Stock
    Jul 23 2010
    arizona
    Quote Originally Posted by seal66 View Post
    I did a lot of stuff I haven't shared and probably wont. I use meth to cool my charge temps and regain lost power, not for a fuel source.
    Aug 05 2011
    CO
    So pretty much not going to help the platform grow for fueling? Eh its whatever. I am testing new injectors for e85 atm.
    Aww i thought you used it for supplemental fueling. Right on
    Sent from my SM-G920P using Tapatalk
    2008 Audi A4 2.0T
    2015 A3 8v P-Stock
    Jul 23 2010
    arizona
    Even if I had a fuel setup that was capable of 1000whp no one would use it, there's only like 2-3 guys who want to make over 500whp. I saw those, what are you looking to get out of them?
    Mar 24 2013
    Oakdale, CT
    I want more than 500 awhp!
    -Adam
    Jun 17 2013
    jersey city nj
    Dont worry....With that set up your working on. Your gonna need a fuel truck following behind you
    Aug 05 2011
    CO
    Not many people want to go above that cause its the current threshold. Once solutions are brought forth and people know then more are gonna move past 500...
    If they do what they are supposed to do I should have no problem reaching just under 500 on e85 and should still have head room.
    2008 Audi A4 2.0T
    2015 A3 8v P-Stock
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by vce1232000 View Post
    That's what I'm worried about lol.
    -Adam
    Mar 24 2013
    Oakdale, CT
    Are you talking about the Cobalt SS injectors?
    -Adam
    Jul 23 2010
    arizona
    One of the 2-3 people I was talking about
    Aug 05 2011
    CO
    I drive a fuel truck, all you gotta do is hire the company I work for ha ha.
    2008 Audi A4 2.0T
    2015 A3 8v P-Stock
    Aug 05 2011
    CO
    No sir, different injectors. Btw I remember reading somewhere that the ecotect 3.5 or ecoboost injectors might work....
    Also, do the new q5 injectors seem like a cheap upgrade for running e85 on say a k03 or ko4. They are e85 compatible.
    2008 Audi A4 2.0T
    2015 A3 8v P-Stock
    Aug 05 2011
    CO
    I do want to go above 500 someday but at this time it just doesnt seem feasible
    2008 Audi A4 2.0T
    2015 A3 8v P-Stock
    Oct 24 2015
    Perth, WA
    This is a strange attitude for the community here
    My respray thread
    Dec 19 2012
    Europe
    Quote Originally Posted by Okedokey View Post
    You don't know DRAKLORE
    Although if you need a grille DIY.....
