$400 Shipped
BEST QUALITY DIRECT FIT!!!
BRAND NEW TEST PIPES * CAT DELETE * PIPES
FITS
28 WHP GAINS / 9 WTQ
S4 S5 Q5 SQ5 A6 A7 WITH 3.0T ENGINE
WILL ALSO FIT 3.2 NA ENGINE NO DYNO TEST DONE CAN OFFER DISCOUNT FOR DYNO RESULTS
100% OEM FITMENT, UTALIZED FACTORY MOUNTS
WILL FIT DSG OR MANUAL TRANSMISSION
28 WHP+ GAINS AND BETTER THROTTLE RESPONSE
FREE SHIPPING
MADE IN USA
HIGH QUALITY T304 STAINLESS TIG WELDED
Product Features & Benefits
+28 WHP & +9 WTQ
Designed and Manufactured in the USA
T304 Stainless Steel materials
Completely Tig welded
63.5mm (20% increased diameter) Inlet and Outlet design (50.8mm on factory cats) match ported to utilize factory gaskets
Reduces weight by 11lbs. (stock cats weigh in combined at 19.2lbs. Cat delete pipes weigh in combined at 8.2lbs.)
Low profile design
Mandrel Bends
Laser CNC cut OEM style mounting flanges (No welding or cutting required)
Designed to work with stock and most aftermarket stock mounting exhaust systems
Direct fit
Will add more sound to your exhaust note
Reduced Exhaust Gas Temps
