Results 1 to 19 of 19
Thread: 12.5 @ 107
    Veteran Member Three Rings importraceram's Avatar
    Feb 20 2012
    e90 M3
    NH
    12.5 @ 107
    I'm sure many of you remember that thread from a few weeks back of the "stage 2" (which ended up only being the stage 1 file) 12.8@109. Well I went back to the track tonight on two updated beta files (both stage 2 ECU and TCU w/4k launch). Before I left I had EPL check their server to confirm that the proper files were successfully loaded, they were. Boom I'm good to go.
    Get to the track, check in, and run right away. This actually happened to be the best run of the night (right lane)
    [IMG][/IMG]
    DA wasn't quite record setting but could have been worse. This was a check ~30 mins after the run.
    [IMG][/IMG]
    Here are the last 3 runs. The last run (right lane) I didn't use LC, and kept it in manual mode thinking it would shift ~7100 and I would pick up some mph, but yet still managed to pull close to same 60 times as the middle two runs (left lane both times). So I'm thinking the right lane was certainly better prepped. Had I chose the right lane every pass with LC I think I would have pulled consistent ~12.5's but who knows. Bottom line is the trap is absolutely putrid.
    Curious to hear everyone's thoughts... Below are the other 3 slips and a video my buddy took of the first run (best one). For some reason he cut it early .
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    https://m.youtube.com/watch?v=-7OargxtgbY
    Current: 2010 Meteor Gray S4 6MT- APR Stage 2, XLR8 196.5mm Crank Pulley, MercRacing HX, CTS Intake
    Past: B7 S4, B8.5 S4, B7 RS4
    Stage 2 Banner Advertiser Four Rings
    Sep 06 2007
    Obviously somethings not right here. I specially checked in to see results from you an 2 others.... Let's circle back Monday and discuss as we had people using the same files go much faster this evening. Sorry it wasn't what you were looking for but we'll get to the bottom of it.
    Feb 20 2012
    e90 M3
    NH
    Quote Originally Posted by Tony@EPL View Post
    Thanks Tony. What were the times of others?
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    Agreed with EPL. Stage 2 should be doing better than 12.5.
    Jul 21 2004
    South Florida
    You need to run some data logs to find out why the power isn't there. Data logs are key. I'm sure you will get it figured out if you are willing to do a little diagnostic work. Yes your car can be running much faster bur keep in mind for every one person who posts their 11.8 run there are 10 who don't post there mid 12 runs. It takes a bit of patience and willingness to data log for some cars to make the full power potential.
    mike
    2018 Audi S5
    Gone-
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    Quote Originally Posted by bhvrdr View Post
    mike
    agreed, datalog will tell you a bunch if you are not running optimal times. It'll answer questions such as: were you hitting ignition targets? what were your IAT's throughout the run? What about LC behavior? flatfoot launch behavior? bypass valve? EGT? list goes on and on
    1000ft D/A's are not terrible by any means, you can land some great times in that D/A.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Feb 20 2012
    e90 M3
    NH
    Thanks for the responses. I don't have access to VAGCOM, I don't have an android for the Torque app, and no P3 gauge yet... Other solutions?
    Jan 09 2008
    Winnipeg
    I think you need to make the investment and get a VAGCOM cable assuming you have a laptop to run the software...it is they tool for the job.
    Aug 09 2015
    Sarasota, FL
    Plus it'll help Tony provide a solution and make adjustments if necessary. You can resell it as well, so its worth its keep. See if a local member can loan you one or help you log.
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Probably needs some more timing 😃
    But it also sounds like a slow track from what people have said. Could you tell me what other cars were there and what you saw them running? Like newer mustang GT's are a good marker car, usually half the cars at any given dragstrip are 2012+ Mustang Gt's. They are a good car to gage how fast the track is, a stock one should be running High 12's@ 109-112.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Feb 20 2012
    e90 M3
    NH
    I guess one positive about this is I'm happy with that 60ft time on my first run.
    Feb 20 2012
    e90 M3
    NH
    Quote Originally Posted by fitzydude View Post
    Slow track or not should have easily been able to trap more than 107. No didn't really get to see anything else comparable that I recall, spent most of my time in the staging lines. I think my buddy, with an ML63 (as seen in video), and I were the only two Germans there. Gotta love NH lol.
    Veteran Member Three Rings shoe3k's Avatar
    May 18 2015
    weedwhacker
    No where
    It's almost as if you don't have a pulley installed. Your 1/8mph speeds should see major improvement just due to the pulley spinning the SC faster in the entire RPM range. As others have said, I would invest getting VAG cable to do some logging. That is the first thing I did when I ordered my Stage 2+.
    Previous: |'18 Golf R | '17 S6 | '15 S4 | '15 STI | '12 GLI Autobahn | '08 Passat | '04 R32 | '05 GTI 1.8t |
    Oct 31 2010
    massachusetts
    Quote Originally Posted by importraceram View Post
    I ran my car up at New England Dragway. I have the APR stage 2 w/ TCU tune and Roc-Euro intake, so to give you a reference my best time was...
    1.745 - 60'
    5.048 - 330
    7.799 - 1/8
    89.15 - MPH
    10.172 - 1000
    12.162 - ET
    115.16 - MPH
    It was about 60 degrees out the day i was there.
    Veteran Member Four Rings Acejam's Avatar
    Dec 22 2009
    MA
    Quote Originally Posted by billy17425 View Post
    1.745 - 60'
    5.048 - 330
    7.799 - 1/8
    89.15 - MPH
    10.172 - 1000
    12.162 - ET
    115.16 - MPH
    Was this on 93 pump? What year S4? Thanks!
    2014 Brilliant Black S4
    DSG / Prestige / Black Optics / Sport Diff / B&O / Carbon Atlas Inlays / Magma Leather
    Modifications: APR Stage 2 Dual Pulley + TCU, JHM 187mm Crank Pulley, APR Open Intake, APR CPS, AWE Touring Exhaust (90mm Silver), KW HAS, 034 Rear Sway, 034 Mount Inserts, Hawk HPS 5.0, S5 Rotors w/ PS4S (Summer), Peelers w/ LM-32's (Winter)
    Feb 20 2012
    e90 M3
    NH
    1.745 - 60'
    5.048 - 330
    7.799 - 1/8
    89.15 - MPH
    10.172 - 1000
    12.162 - ET
    115.16 - MPH
    When I asked what were the times that was intended for Tony as he implied other EPL guys ran that same night. I'm well aware of what APR can do. No doubt a legitimate tune.
    Dec 22 2009
    MA
    It's still good to know what an APR car can do at NED though :)
    Veteran Member Four Rings BoostEasy's Avatar
    Aug 07 2013
    2014 S5, S-tronic
    NE
    Start with the basics:
    1) Weigh you car in the prep as you race it. A number of tracks will have scales either the large drive-on type or portable ones. If the track doesn't have one you can try a truck stop or dump as they will usually have one graded in 10lb increments. jack/spare, etc all weigh something and gas is about 6lbs per gallon. Weight matters.
    2) Get a vag-com and small 7" windows tablet like a Dell Venue and mount it on the dash (I like Arkon SM679) and start logging. http://www.audizine.com/forum/showth...blet-and-Mount
    Logging is absolutely essential to understanding your car. Asking other people for advice is great, but for $400-$500 invested in vag-com, tablet and mount you can cut to the chase and get the exact info you need- specifically if you're excessive spark retard or lowered boost from high IATs etc. Logging is a little bit involved to get started but it is something a number of people have experience with and will be happy to offer help.
    It's tough to diagnose without logs. Make yours and Tony's life easier by picking up the right tools and get to it.
    Good luck!
    2014 S5 S-tronic. Phantom Black, 19" AG M590s, Akebono Pads, OEM RS5 Grill, Alu-Kreuz, Black Alcantara, MMI, Quattro Sport Diff, B&O sound, side assist.
    2011 335xi (gone)
    2008 335xi (gone)
    Oct 31 2010
    massachusetts
    I know...i wasn't comparing tunes or even trying to show what an APR tune is capable of. I was trying to give you a comparison from a car with similar mods on the same track in similar weather.
    Acejam I have a 2012 on 93 pump.
    Also i have a VAG-COM cable if you wanted to get some logs to see whats going on.
