Results 1 to 12 of 12
    Senior Member Two Rings BumbleBee's Avatar
    Nov 09 2008
    Autobots
    Audi A6 3.0 3.2 TFSI TEST PIPES CAT DELETE Pipes 100% OEM Fitment TIG Welded
    $400 Shipped
    BEST QUALITY DIRECT FIT!!!
    BRAND NEW TEST PIPES * CAT DELETE * PIPES
    FITS
    28 WHP GAINS / 9 WTQ
    S4 S5 Q5 SQ5 A6 A7 WITH 3.0T ENGINE
    WILL ALSO FIT 3.2 NA ENGINE NO DYNO TEST DONE CAN OFFER DISCOUNT FOR DYNO RESULTS
    100% OEM FITMENT, UTALIZED FACTORY MOUNTS
    WILL FIT DSG OR MANUAL TRANSMISSION
    28 WHP+ GAINS AND BETTER THROTTLE RESPONSE
    FREE SHIPPING
    MADE IN USA
    HIGH QUALITY T304 STAINLESS TIG WELDED
    Product Features & Benefits
    +28 WHP & +9 WTQ
    Designed and Manufactured in the USA
    T304 Stainless Steel materials
    Completely Tig welded
    63.5mm (20% increased diameter) Inlet and Outlet design (50.8mm on factory cats) match ported to utilize factory gaskets
    Reduces weight by 11lbs. (stock cats weigh in combined at 19.2lbs. Cat delete pipes weigh in combined at 8.2lbs.)
    Low profile design
    Mandrel Bends
    Laser CNC cut OEM style mounting flanges (No welding or cutting required)
    Designed to work with stock and most aftermarket stock mounting exhaust systems
    Direct fit
    Will add more sound to your exhaust note
    Reduced Exhaust Gas Temps
    "The least likely can be the most dangerous."
    2001 S4 GT28RS SSP Tuned
    2004 Audi RS6 SSP Tuned - 6 Speed Converted GT30's
    2006 Porsche 911 Turbo - SSP Tuned -
    2013 Audi S4 SSP Tuned
    2016 Audi S3 SSP Tuned
    Nov 09 2008
    Autobots
    BUMP
    Senior Member Three Rings Indskyz's Avatar
    May 31 2016
    Virginia Beach
    PM sent
    2010 A6 Prestige 3.0T
    GIAC Stage 2+ 93 & 100 Octane files
    AWE 57.55mm / JHM 179mm Dual Pulley (3.110 Ratio)
    PLM 26"x7"x2" additional HX
    Roc Euro Intake
    2.5" Custom Cat-back Exhaust w/Magnoflow Resonated X-Pipe and Mufflers
    Gutted CATs
    ST Coil Overs, H&R Rear Sway Bar
    19"x8.5 Avant Garde M590s Antique Bronze
    Spyder Tail Lights
    May 31 2016
    Virginia Beach
    Are these still available?
    Roc Euro Intake
    Gutted CATs
    Spyder Tail Lights
    Nov 09 2008
    Autobots
    Quote Originally Posted by Indskyz View Post
    yes still have
    Established Member Two Rings Coops_5221's Avatar
    Feb 27 2017
    Leicester, England
    Are these for the C7 A6 only?
    Sent from my ONEPLUS A3003 using Audizine mobile app
    2015 RS7
    SRM Intake
    Milltek (I think) DPs
    ECU and TCU tune
    Nov 09 2008
    Autobots
    Quote Originally Posted by Coops_5221 View Post
    No they fit S4 S5 A6 Q5 SQ5 and Q7 and A7
    Feb 27 2017
    Leicester, England
    Quote Originally Posted by BumbleBee View Post
    Ok, thanks. What A6 do they fit, C7 only?
    2015 RS7
    SRM Intake
    ECU and TCU tune
    Dec 01 2007
    Orange County, NY 10918
    Assuming you need a tune to run these?
    Sent from my SM-G900V using Tapatalk
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    @skiguardusa www.skigaurd.com
    Feb 17 2010
    1991 Toyota MR2 Turbo
    Minnesota
    Do you have any videos of acceleration or general driving? Any drone when driving around? Thanks for any input! I have a 2013 Audi S4 GIAC Stage 2 (dual pulley soon!) for reference.
    Jun 19 2016
    beaver dam, WI
    Are theses still available?
    Veteran Member Three Rings toastsauce's Avatar
    Apr 08 2014
    Jersey City, NJ
    Confirming these will fit a 2014 Audi S5 and you have in Stock. Can these be coated by your shop?
    2014 Audi S5
    034 Stage 2+ ECU & TCU | 75mm TB | Ported SC | Roc Euro CAI | Merc Hx | B12 Pro Kit | 034 Rear Sway + Links | 034 Motor Mounts
    JHM Test Pipes | EC Alu Kruez | CR-15 | EC T&B Diff & Trans Mounts | USP SS Brake Lines | EBC Yellow Stuff Pad | BP Slotted & Drilled Rotors
