Results 1 to 10 of 10
    Senior Member Three Rings jrodpikap's Avatar
    Oct 23 2006
    2004 A4 USP 1.8T Stage 1 & 2000 A4 1.8T
    Conshohocken, PA
    Center Armrest Console Permanent Removal?
    I was thinking about removing the Center Console Armrest and Armrest Assembly...entirely. All it does is get in the way.
    My question is has anyone removed this entirely, and is there a plug solution for the hole that is left when the armrest assembly is removed?
    Would love some advice, thanks!
    _______________________________
    -2000 A4 Black 1.8T
    -2004 A4 Red Stage 1 USP 1.8T
    Aug 26 2005
    The center arm rest is an option.
    Console plug
    8E0 863 301 A 1ea.
    Vorsprung durch Technik
    Sep 16 2010
    Central Wash
    Console plug
    4B0 864 211 A, 1ea.
    That part# corresponds to #21 in this picture:
    Which is not an armest 'delete' plug or trim, it's the soft round plug that goes on the bottom side of the armrest to cover an oval hole...for I can't figure out what. Cable routing or something for an option none of us got.
    I have never seen an OEM armrest delete plug available for an Audi. Always for VW, not for the Audi console.
    Aug 26 2005
    The part #17 is the part number I posted from Parts link 24. Post edited, thanks for the heads up.
    Veteran Member Four Rings prizmatik's Avatar
    Dec 15 2009
    Hell hole
    Would love to see before and after pictures if you complete this task.
    Sep 16 2010
    Central Wash
    googlerizing that part# I find:
    And it says it refers to #15 in the illustration. Which is described as a 'mat' or insert, which seems to be the same thing as #17 above.
    Not being picky, I am actually super interested in finding a thing like this. I think I have never seen an OEM armrest delete for an A4. I have seen a picture or two of consoles that were supplied WITHOUT the hole at all, in Europe obviously, but never in the U.S. .
    I'd love to find one and I've been passively searching for about 6 years since I had my 6 speed 3.0, in that car I ended up making my own.
    I'm not a big fan of the armrest, especially in a car w/ manual trans. Personally I don't think it exists..but I wish it did.
    Feb 27 2011
    Winnipeg
    would love to see pics of this as well, my B5 came with no armrest and I added one since it has no storage, with the seat trays in the B6 I'm seriously debating deleting mine as I don't use it and have it flipped up so I can shift without banging my elbow.
    Oct 23 2006
    Conshohocken, PA
    Screw it i'll leave it in and just keep it up all the time.
    -2000 A4 Black 1.8T
    Aug 26 2005
    Yeah, the console options in Europe, specify the arm rest as optional. I am not sure if an armrest delete part exists. From the parts diagram I thought the #15/17 may be the hole cover.
    However, a Euro A4 console probably doesn't have a cut out for the armrest unless the armrest is fitted at the factory.
    Jan 09 2012
    MA
    If you want to make up your own, here are the dimensions
    http://www.audi-sport.net/xf/threads...armrest.91609/
