Results 1 to 6 of 6
    Veteran Member Four Rings reece_2212's Avatar
    Apr 22 2016
    Alberta, Canada
    What could be the cause of this noise?
    Whenever the car moves up and down (i.e going in/out of the car) or when I drive at a low speed (20-30 km/h) this squeaking noise comes from the rear drivers side. What could it be? Control arms? Struts? Thanks in advance.
    '96 A4 2.8QM - (RIP Avocado) <3
    '01 A4 1.8tQM - GT2860RS Elim, 550cc, APR Carbonio, Clutchmax Stage 2 w/ SMFW, APR FMIC, IE Rods - Bilstein B8, Tein S Tech, 034 Trans Mounts, ECS Poly Snub, Stern Engine Mounts - B7 A4 Front Brakes, C5 S6 Rear Brakes, Stoptech Stainless Lines - eBay SS, 3D Printed Shifter Cage, JHM Linkage Bushings -
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    My rear drivers spring isn't in the lower spring perch the right way and so it runs on the strut back there.
    Apr 22 2016
    Alberta, Canada
    Quote Originally Posted by Davdraco1 View Post
    I took a look at that & other than rusty springs, everything seems to be sitting right
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    That was worse than mine was but similar.
    Mine was the bushings in the upper suspension arm. The metal center becomes unbonded from the rubber and will squeak. The bushings are cheap and there was a thread about it not long ago, but they are kind of a bitch to replace
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Apr 22 2016
    Alberta, Canada
    Quote Originally Posted by redline380 View Post
    Thanks! I'll work on getting those changed.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by reece_2212 View Post
    Info and kind of a DIY here- http://www.audizine.com/forum/showth...l-arm-bushings
    2000 S4- Working?
