Results 1 to 14 of 14
    Feb 20 2014
    Charlotte, NC
    A4 Engine Won't Turn Over
    It has happened about 5-6 times in the last 5 weeks that when I go to crank my 2011 A4 Quattro it won't turn over. It's almost like it gets to the peak where it would crank and it just won't fully turn over. I replaced all 4 spark plugs thinking that could be the problem but the day after I did that it happened again. I had the battery tested and it checked out perfect. I took it to a local shop here in Charlotte, NC and they had it for 2 days and couldn't figure out what was going on. It happened where it wouldn't crank for them 1 time but didn't do it again so they couldn't pin point the problem. It doesn't happen every time I crank it and once it does crank it never shuts off. I have no idea what is going on. Any suggestions? The techs at the shop I took it to said one thing that it could be was the older software I had on it. They said they weren't certain but thought that might be the issue. However, they said I had to go to the dealer to get it updated. Really not in the mood to get bent over so was hoping someone could help. If it happens to be a software issue anyone in the Charlotte, NC area that can help me so I don't have to go to the dealership? Hopefully someone knows what the deal is. Anyway thanks everyone!
    Aug 06 2012
    Parker, CO
    Does this sound like the dreaded timing chain tensioner others have dealt with?
    Vehicles: '16 VW Touareg, '13 allroad. '06 VW Touareg
    Senior Member Two Rings oshwi's Avatar
    Oct 07 2013
    nutley, nj
    Did you scan for any faults? That shouldve been the first step to diagnose it. And as treg said. It does sound like the dreaded timing chain failure. Dont crank the car anymore till you scan it!!
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    To be clear and on the same page, does the motor "spin" or is the issue that it isn't spinning/turning the motor over and you are getting multiple clicking sounds?
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
    Feb 20 2014
    Charlotte, NC
    There aren't any clicking sounds at all. It sounds like it is going to start like it normally would and it's almost as if it gets to the "peak" and then just stops. Not sure if that really makes much sense.
    Jun 12 2013
    Ah, so the starter 'is' turning the motor over but it never 'starts'? If that's the case, yeah, more than likely good ole' timing tensioner failure.
    Build Thread
    Feb 20 2014
    Charlotte, NC
    Yes. What's an estimated cost to have that fixed?
    Jun 12 2013
    Ouch... hard to say. The first issue of concern is has any further damage occurred - you wont be able to know/tell unless it is taken apart. You can tell based on how many teeth timing has jumped. If you're 1-2 off, very good chance valves, head and pistons aren't damaged. If the count has jumped more than 2 teeth, the probably of further damage drastically rises.
    With gaskets, hardware, etc. you're looking at a good $1300-1500 alone. That's not including labor.
    Search for the DIY: motor repair thread I started to familiarize yourself with all the details.
    Build Thread
    Feb 02 2016
    What's your mileage?
    Feb 20 2014
    Charlotte, NC
    120K drive a shit load for work
    Jun 12 2013
    Yeah, you're up there for sure. Guys, you got to remember, it's not so much the mileage but the number of 'starts'.
    Build Thread
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Quote Originally Posted by Allowencer View Post
    I think it's a little early to conclude that.
    He said the no crank issue is intermittent.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Feb 20 2014
    Charlotte, NC
    Exactly. There are times where I will crank it numerous times before it won't crank. Typically it will crank and run fine for a few days before it won't crank again. I had it at the shop and it cranked for them every time they tried to figure out what was wrong.
    Jun 12 2013
    Not necessarily. That is a symptom; hard / no starts. It's because the chain jumps, like a bike chain and then it catches the sprockets again. It still stays in sync though.
    This can be easily confirmed by popping off the top timing cover and rotating the motor over. If you see the chain jump, like a bike chain, well, there you have it [unfortunately].
    There isn't much to 'start' a car. Compression, fuel, spark and a working ECU. You can check compression with a compression test. Fuel can be checked by checking the rail pressure (mind you it's a VERY high pressure, a normal fuel pressure gauge will not do).
    Build Thread
