Results 1 to 6 of 6
    Veteran Member Four Rings RockJGC's Avatar
    Sep 28 2014
    NY/NJ metro area
    Looking for gear ratio info - help!
    Does anyone have access to a shop manual or something similar to look up the gear ratios for the 2011 A5 2.0T 6MT? I know that The B8 A5 and the B8.5 A5 uses different ratios in the manual transmission, but I can only find the ratios for the B8.5 cars when I searched online.
    If anyone is interested, here's the ratios for the B8.5 6MT in the A5:
    1st: 3.778:1
    2nd: 2.050:1
    3rd: 1.321:1
    4th: 0.970:1
    5th: 0.757:1
    6th: 0.625:1
    Final Drive: 3.693
    Veteran Member Four Rings Sgibb16's Avatar
    Jul 02 2012
    2012 A5 & 2002 Passat Wagon
    Fredericksburg, VA
    1st: 3.78
    2nd: 2.05
    3rd: 1.32
    4th: 0.97
    5th: 0.81
    6th: 0.69
    Final Drive: 3.69
    Edit: Also This is what I found for the 2013 A5
    1st: 3.667: 1
    2nd: 2.158: 1
    3rd: 1.520:1
    4th: 1.133: 1
    5th:0.919: 1
    6th: 0.778: 1
    Final drive: 3.682: 1
    https://www.audiusa.com/content/dam/...edia%20kit.pdf
    2012 A5 P+ | Sports Package | 6MT | 35% Tint
    REVO Stage II | AWE Quad Exhaust | 034 HFC | E-Codes | FK Silverline Coils | JHM Short Throw Shifter | Eurocode HFIC Pipe | Roc Euro Intake
    TR8 Intercooler | CTS Silicone Hose Kit & Turbo Outlet | CR-15 Strut Brace | Alu Kreuz | S-line Front & Rear Bumper Conversion
    Sep 28 2014
    NY/NJ metro area
    Okay, thanks. I'm not sure why that doesn't match the ratios on the 2013 A5 brochure. I wonder if it's a typo on your link, since the S5 has the same exact ratios. I'd think they would be different, no?
    And where did you find the B8 ratios? I looked all over and couldn't find them anywhere!
    Veteran Member Three Rings ParadigmTony's Avatar
    Apr 02 2015
    Rochester NY
    But I also don't remember the 8 and 8.5 having different ratios. But I also don't remember what I ate for lunch either
    //B8 A5 // 6MT DSB Pearl // Roc-Euro // APR // AWE // BBS // Bridgestone // StopTech // // K04/Stage 3v3/FMIC/Roc-Euro Intake/Test pipe-AWE touring/100oct life/19x10 CI-R/RE71R/ST60 BBK //
    Sep 28 2014
    NY/NJ metro area
    Yup, definitely different. What caught my eye was that they increased the MPG rating and I wondered why. Then I researched the gear ratios and discovered that they changed the gear ratios to make the B8.5 better in terms of fuel economy. The B8 had slightly more aggressive gearing though...
    Jul 02 2012
    Fredericksburg, VA
    Quote Originally Posted by RockJGC View Post
    I found them on like a edmunds type site.
