Results 1 to 8 of 8
    Jun 04 2012
    Greenville NC
    B6 S4: Hood Release cable broke, looking for advice on how to open the hood now
    This morning when I tried to open the hood of my B6 S4, I pulled the hood latch and I believe it has become disconnected from the locking mechanism on the hood release. I've searched the forums for advice on how to open the hood when this happens, but I'm looking for specific details on how to approach this. I tried the remove the grill technique, took out one of the bolts that secures the hood, but am simply unable to get to the other bolts with the tools u have, so that option is pretty much put the window. Can someone explain to me how the "remove the belly pan" option works? I have the belly pa removed but what am I specifically looking for when it comes to releasing the hood from underneath? Pictures would be greatly helpful. Thank you for any advice!
    Established Member Two Rings pandapod's Avatar
    Feb 09 2014
    Connecticut
    If the hood latch wire is exposed, or if you can find and get to it, see if you can give it a (real) good tug to pop it open. Unsure how to access it from under vehicle but believe there is a thread on it somewhere...
    Sprint Blue Pearl B7 S4 with JHM IM spacers, K&N drop-in filter, 034Motorsports Density Line motor mounts, 034Motorsports sway bay end links
    Jan 29 2010
    north ga
    on a b6 it's easy. from the outside, pop the tabs that hold the upper grill on so you can reach the release by hand
    Oct 02 2006
    Wadsworth,OH
    When my hood pop cable broke I was able to unlatch the hood from under the car. Remove the belly pan and grab a long screw driver/pry bar/piece of flat bar stock etc. something long enough to push the locking tab open. Hood should release, though it may take a little finessing. Good luck!
    Jason
    Veteran Member Four Rings evildsmr's Avatar
    Sep 13 2012
    04 Imola V8, '21 Army Green Taco
    Denver
    I've tried all the long screw driver tricks on my b6 s4 and every other trick and the only thing that works is pulling the grill and taking off the three bolts that hold the latch to the hood. If you go this route be prepared it takes forever!!!! Like about an hour to get those three bolts out cause its only like 1/4 of a turn. Good luck!
    Sent from my Nexus 6 using Tapatalk
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    Quote Originally Posted by evildsmr View Post
    This is what I had to do. Two of the bolts actually aren't toooo bad, that third one way in the back takes longer than the other two combined. I think a ratcheting wrench would probably make it much faster as well. I didn't have one at the time.
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    May 01 2015
    GA
    I tried for 2 days when mine broke. Took it to audi and they had it open in 45 mins. $300 total for them to open it up, new latch cable, and labor to install it.
    Veteran Member Four Rings A4Maine-iac's Avatar
    May 03 2010
    2012 TT Sold
    Maine
    3ft ext and car on ramps . Done in 10 minutes from under the car.
    http://www.fixya.com/cars/t7317720-b...cable_broke_a4
    2002 A4 1.8T - sold
    2007 DTM S4 -Sold Sound clip - https://www.youtube.com/watch?v=bGz60n-31jc
    2012 TT - TTS Rear & Exhaust- UNI Stage 1+ " More to come"
    2021 SQ5 - " Just getting started
