Results 1 to 10 of 10
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    Fully maintained stage 2 01.5 6 speed
    Realy didnt want to have to do this. But the time has came
    Baby due in 3 months and need the money.
    Its a 6 speed 2001.5 Stage 2 S4 twin turbo v6 awd with 154k miles. Car has a german reiger body kit on it and clear corner mod on some light weight 17s
    Car is 100% solid , extra tight responsive steering
    Bought car september 2014 with 127k miles and plans on eventually stage 3. So as things wore out i upgraded to be ready for stage 3 used all good brand parts not cheap parts. All work and parts i mention replacing have been done in past 20k miles and less then a year and a half,and cost me over $12000.... i have receipts for 95% of work done. And All by reputable shops
    Car is pretty fast for stock turbos. Drag raced it three times and pulled a 12.99 @108 on race gas.(have go pro videos inside and out if interested)
    0 leaks and no burning oil!
    ***!!! Fully maintained/ up to date on everything and good to go for over 70k miles!!!***
    Interior is a 8 out if 10
    (Very clean no rips in seats)
    Full milltek catted turbo back exhaust (cost $3600 new! (I got used for $1200) sounds amazing and is ALOT lighter then stock. Its the best sounding/ most expensive exhaust made and to top it off they just discontinued it.
    Got the instrument cluster fixed (no broken pixels it looks perfect)
    Has factory bose audio system with a double din pioneer touch screen bluetooth/dvd player
    Shocks and struts were replaced 3k miles ago with blistein hds!
    Random Parts replaced:
    -Oil every 3500 miles
    -Coolant flushed twice in past 30k miles
    -Rear dif fluid replaced with motul
    -Tranny fluid replaced 5k miles ago with fuchs
    -Brakebooster hose
    -Ect sensor
    -All 4 brake calipers rebuilt (fading red paint)
    -New hitachi maf
    -Rear Trailing arm
    -Rear upper controll arm bushings (both sides)
    -Both rear wheel bearings (one oem one f.a.g)
    -Front and rear oem springs (old ones were broken)
    -Rear upper strut mounts ($300 old ones were bad)
    -Fpr
    -Pem springs
    -Instrument cluster fixed
    -Icm
    -A coil or 2(and comes with a spare)
    -O2 sensor
    -All 4 calipers are rebuilt.
    -Intercoolers
    -Serpentine belt/ tentioners
    -Starter
    -Waterpunp
    -Timingbelt/ tensioners
    -Valve covers gaskets Cam plugs/ seals. Cct seals
    -Thermostat and upgraded housing
    -Leaking coolant pipes/hoses
    -Kuhmo all seasons (less then a year old)
    Upgrades (prices are parts only not labor)
    -Solo motorsports stage 2 tune 93 octane and race gas tune and Sms flash loader ($900)
    -Milltek turbo back catted exhaust with wrapped downpipes (paid $1200new is $3600)
    -Forge 007s($300)
    -034 silicone throttle body boot($70)
    -Ecs full stainless steel brake lines($180)
    -Ecs rear dif mount($170)
    -034 rear dif carrier bushings($50)
    -Meyle hd controlls arms($450)
    -034 motor and tranny mounts ($250+)
    -Spec stage 3+ disk wih rs4 pp and luk dmfw($1200 in just parts not including labor. Good for 5-600 ft/lb of tq)
    -Blistein hd shocks+oem instalation kits($650 3k miles ago)
    -Samco Blue silicone boost hoses($200)
    -Powerstop drilled and slotted brakes front and rearĺ $320)
    -Lightweight 17" rims (less then a year old)($530)
    -Led liscense plate bulbs ($50)
    The tune is a solo motosports stage 2 tune with egt delete.this comes with a $300 flash loader to switch between different tunes.The flashloader has 4 tunes on It one for 93 octane18 psi, stock 7 psi, and for ms109 race gas at 19psi. You can Pay a few bucks to upgrade to stage 3 software in the future (will only cost aeound $150 to 200wich is main reason i went sms stage 2 with flashloader so its cheap for stage 3) cost me around $900 total
    THE CAR IS DRIVEN AROUND ON THE STREETS ON STOCK 7 PSI TUNE AND CAR IS NOT BEAT i spent alot of money to be able to switch back and forth from 18 psi to the stock 7 psi for daily driving to not beat the car or turbos. (still plenty fast on stock tune)
    Work just done within a year and 12k miles!!!
    Timing belt kit, valve cover gaskets and all related seals all replaced by a audi tech at a local shop with oem parts. Also replaced starter and thermostat, METAL waterpump, thermostat, metal thermostat housing and fixed a few other coolant leaks and put a set of intercoolers that were alot better condition and lower miles then old ones. All work done by german auto sport. And cost me over $2300
    The only bad thing is rust at rear quarter panel (quoted 400-900 to fix)
    Car fax is clean and says cars worth $1700 more then blue book. Thats not including timing belt just done and expensive no longer available bodykit and what not.(i can provde the carfax)
    $6900 firm,(will sell for slightly less ifi put back to stock parts depending on what how lowyou want to pay) will keep car for any less. I payed 7000 for the car and put 12k+ into it to get it to this condition
    Will trade for a decent car plus minimum of $4500 cash. (So a cheap car plus cash)
    Asking price comes with a bunch of spare/stock extra parts and a second set of 18" rims/ tires (1 rim has a crack on inside and leaks air within 2 days quoted $110 to fix)
    Car looks alot newer then a 2001 paint is exteremly shiny still. Every one gueses 06-08 (that dont know audi)
    First person to come see car WILL buy it.
    $6900
    Thank you
    Aug 04 2014
    Gloucester MA USA
    Bump , updated add a little. Getting pissed off some one keeps flagging it on craigslist so i have to keep reposting and uploading pics.
    Aug 04 2014
    Gloucester MA USA
    Forgot to mentionlowest id take is 5000 cash if i put back on a stock exhaust, shifter, rear dif mount, intake, bipipes, dvs,tune and the rims that have one cracked. (Car would be Basically stock with upgraded motor/tranny mounts and upgraded clutch with all maintenance done )
    Aug 04 2014
    Gloucester MA USA
    Put back in stock intake, bipipes and a custom moded oem shifter and lowerd car price to $6900!
    Aug 04 2014
    Gloucester MA USA
    Jul 04 2012
    Woodbridge, VA
    Weeeeellll... There he goes!!!
    Free bump brotha. Clean ride. Good luck with everything.
    Aug 04 2014
    Gloucester MA USA
    Quote Originally Posted by vavJETTAw36 View Post
    Thanks alot!!
    Its sad having to do this but baby comes first....
    We all know ill be back eventually lol
    Veteran Member Three Rings saucemanpc's Avatar
    Jun 08 2012
    South of Boston, MA
    Where are you located?
    Sent from my SM-N920T using Tapatalk
    2002 S6 Nemo Blue 01E 6MT swap goodness - Rear Muffler Delete w/magnaflow resonated tips. 19" OEM Rotors.
    Previous:
    2001.5 S4 Stage 2 Sold
    2009 Premium A4 2.0T 6MT Deep Sea Blue, 35% Tints, Reiger Clone Ebay Trunk Lip
    Sold
    Aug 04 2014
    Gloucester MA USA
    Gloucester ma, a little north of boston
    [email protected] is easiest way to contact me or pm me for my cell number
    Aug 04 2014
    Gloucester MA USA
    Guess this is on hold with blown turbos
