Results 1 to 15 of 15
    Veteran Member Four Rings swoardrider's Avatar
    Mar 23 2006
    '06 A4Q 2.0T
    Santa Cruz, Ca
    Anyone on AZ pass Cali smog with a HPFP and JHM or APR software?
    Trying to make an executive decision on whether or not to install my HPFP I've had laying around.
    Thanks
    '06 2.0T S-line Tip
    Stasis/Ohlins Motorsports, Stasis 14.5" BBk, Stasis rear BBK, H-sport rear sway, JHM 2+ tune, JHM 4:1 center diff, 18" Wed'sSports w/ 255/30 Toyo R888 (track), 19" Tenzo-R's w/ 255/35 (street), Stern upper arms, upgraded stereo, Huper tint, RS4 grill, JHM HFC, JHM downpipes,OEM S4 exhaust, track goodies
    Veteran Member Four Rings rongeur's Avatar
    Jun 04 2011
    Clayton, CA
    I passed Cali Smog with HPFP and JHM stock profile. The same could be done with APR stick profile as long as you have he tiptronic version of APR software which does not delete the rear O2 sensor thus disabling the ECU from reaching readiness. JHM tunjng does not prevent readiness.
    CA smog is visual inspection and OBD 2 scan for codes and readiness. There is no longer a sniffer. HPFP look identical to stock pumps and dont affect readiness.
    2008 A4 2.0T Quattro 6MT S-Line QGM
    Stage 3 JHM TD05H-R on a fully built motor
    Build Thread
    Veteran Member Three Rings Older_not_Wiser's Avatar
    Mar 16 2012
    2006 A4 Quattro 2.0T S-Line Avant Quartz Gray - Project Car
    Lomita, California
    Last time I had to smog about a year and a half ago, I was APR Stage 2. I took off the catch can and put stock PCV on, took off test pipe and put stock cat back on. Switched program to stock and drove it for a day or so to make sure I put several drive cycles on the car. I did not have VAG COM at the time so I had a friend with VAG COM check readiness after a day of driving and before taking it in for smog. It showed readiness after a day of driving and smog check was no issue. I am 6MT BTW.
    I am now APR 2+ and expect to try the same in 6 months or so. I am not sure why the Stage 2 and Stage 2+ tunes would treat the rear O2 sensor different. I was told the drive cycles were required to get readiness. I have my own VAG COM now so I will monitor later this year when I have to smog again.
    2008 A4 2.0T Quattro S-Line Titanium Sedan Phantom Black Pearl - Daily Driver
    2006 A4 2.0T Quattro S-Line Avant Quartz Gray - Project Car
    Aug 31 2011
    C7 A6 3.0T Prestige - AEV JKUR
    Lathrop
    Quote Originally Posted by Older_not_Wiser View Post
    To prevent the CEL from being triggered from the OEM catalyst being removed, they prevent the catalyst readiness from running. If the readiness does not run, the CEL will never appear.
    Mar 23 2006
    '06 A4Q 2.0T
    Santa Cruz, Ca
    Quote Originally Posted by rongeur View Post
    Thanks for the reply rongeur.
    Do you have a HFC as well or the stocker? I'm surprised the car would even run correctly on the stock file with the HPFP. I thought our cars needed the correct file to run properly with the HPFP?
    No sniffer?? That's weird. How else would they know if your hydrocarbons were too high? Last time I got smog get 2 years ago I ran the test pipe on stock file, (the shop didn't catch the test pipe on the visual), but it wouldn't pass the sniffer cuz hydrocarbons were through the roof. So I had to put the stock cat back to pass the sniffer.
    '06 2.0T S-line Tip
    Apr 24 2016
    California
    If you're Quattro they can't run the sniffer anyway, unless you take it to a smog shop with two sets of rollers.
    Established Member Two Rings boarderx100's Avatar
    May 25 2011
    Huntington Beach, CA
    I passed smog with APR stage 2 and a HFC..
    Jun 04 2011
    Clayton, CA
    I was fine with stage 2 as well, stage 2+ screwed the pooch
    Quote Originally Posted by Jake@JHM View Post
    This is true, I confirmed a lack of data streaming from the rear O2 in VCDS. Thus, you could try and force readiness a billion times and fail, drive a zillion miles and still not reach readiness.
    Quote Originally Posted by swoardrider View Post
    2 years ago, I was sniffed and failed on HFC, this time around, swapped to stock cat and was only subjected to visual and obd 2 scan
    Quote Originally Posted by boarderx100 View Post
    We are talking about stage 2+
    Quote Originally Posted by RakkCity View Post
    This true but I am pretty sure rollers are supposed to be obsolete with OBD 2 scanning now.
    Build Thread
    Apr 24 2016
    California
    So can they tell you're tuned with the scan? or do they just check for CEL's?
    Jun 04 2011
    Clayton, CA
    On mine, he looked with a flashlight under the hood. I temp disconnected my water meth and tucked away the tubing under my RS4 driver side engine cover and swapped back to OEM valve cover / PCV / cat. I was otherwise with the JHM/FI downpipe and exhaust, lowered etc.
    Then he plugged in his scanner which on the printout searched for readiness and codes.
    The rub is, 2 years ago, same place, same visual and scan but then followed by sniffer on awd rollers which i passed on the APR stock map file for stage 2+ and HFC I failed on the rollers.
    http://www.audizine.com/forum/showth...d-CA-Smog-test
    Now looking back, I was mistaken, I was the same 2+ as this time around which is even more aggravating. Appearently, you are supposed to be allowed 1 non-readiness for our years in the CA Smog legal papers and still pass but wasnt my case. Maybe that is why the rollers were used to pass last time and this time rollers were not used and just failed me, maybe the guy was lazy this time?
    Build Thread
    Mar 23 2006
    '06 A4Q 2.0T
    Santa Cruz, Ca
    Yes, this is exactly the problem I just had. My APR software is turning off the O2 sensor, so smog station won't even hook me up to smog computer. I'm hoping to find a software solution to pass smog and run my HPFP.
    '06 2.0T S-line Tip
    Apr 24 2016
    California
    Why would the HPFP cause you to fail smog? It's my understanding that the upgraded pump just has the capacity to supply more fuel for high boost situations, but operates just like the OEM piece under a stock tune/low RPM. Shouldn't affect your OBD2 at all.
    Am I wrong? This is relevant to my situation too, I just swapped a HPFP on and will be needing a tune here in CA at some point. Figured I'd just swap the stock cat back on (and possibly flash back to stock map) and get readiness then smog it.
    Mar 23 2006
    '06 A4Q 2.0T
    Santa Cruz, Ca
    This was just my guess.
    Back when the HPFP's first came out, guys would install the HPFP's themselves, and then "limp" over to their nearest software dealer and have them reflash to the HPFP software program. So I naturally assumed this meant that the car doesn't run right with HPFP on stock software. I would think that a bad running car would not pass smog. But if they don't even use the sniffer anymore than maybe I'm being paranoid over nothing. I just don't want to spend anymore money on mods if my car is not going pass smog without putting it back to stock, as I will be selling my car in the next 3-12 months.
    '06 2.0T S-line Tip
    Aug 31 2011
    Lathrop
    The car will run just fine on stock software with the upgraded HPFP. It's actually good for the car, as it will prolong the life of the HPFP solenoid because the duty cycle drops with a large pump.
    Mar 24 2013
    Oakdale, CT
    My car ran great on APR stage 1 with an HPFPupgrade stage 1 hpfp.
    -Adam
