Results 1 to 19 of 19
    Apr 13 2016
    Belleville NJ
    Can e-brake burn your clutch?
    I loaned my b6 to someone (I know I regret it) while I was in the Post Office and he forgot to put the e-brake down. I guessed he couldn't see it under the arm rest,I left it in 3 Clicks before he took off,Came back with a strong smell now my rear brake are warped so they done my e brake still work but is not that tight like before But my Clutch pedal feel loose shift all gears but the engagement point is higher is not stiff the way it used to be you know it grab higher,is the clutch is done? No jumping rpm just sometime a slightly vibration when accelerating like going small speed bumps lines.
    Senior Member Two Rings G-Ride's Avatar
    Dec 16 2008
    Imola 2003 A4 1.8TQ 5spd
    Melbourne Australia
    What's an e-brake? Just the parking brake? Clutch disc is probably glazed from heating up?
    Imola Yellow '03 A4 Quattro 1.8T 5 Speed
    :: Motoza Performance Tuned on e85 ::
    : Frankenturbo F21-L : Bosch EV14 750cc Injectors : 3" MAF : Milltek Turbo Back Exhaust : AudiSport Suspection : ER FMIC : Sachs RE Clutch : TyrolSport Brake Kit : StopTech & Ferodo DS2500 : Goodridge SS Lines : Forge 008 : 034 SD Engine & Trans Mounts : Apikol Snub & Rear Diff Mount : Podi & VEI Digital Boost Gauge :
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    I agree with G-Ride. It sounds like your clutch disc is glazed. That would cause the “small speed bump” condition that you described. If the glazing isn’t too severe you might get lucky by driving very gently until you work off the surface glazing. It may take several thousand miles for this to occur. If the glazing is too deep into the clutch disc material you are unfortunately going to need a new clutch.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    No, it won't cause the clutch to burn unless the clutch was actually slipping. I forget to take my brake off occasionally and the clutch never slips as a result, but I also catch the mistake in about 100ft. As long as the clutch wasn't slipping, nothing happened to it.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by redline380 View Post
    I’m speculating that his friend had to slip the clutch quite a bit starting and stopping if he left the hand brake on long enough to destroy the rear brakes. It doesn’t sound like he released the brake within 100 feet. It sounds like he never released it.
    Apr 13 2016
    Belleville NJ
    No way he never release it withing 100ft,He left it on from start to stop 6 min 1.5 miles.When releasing to the engagement point on first gear taking off without accelerating is goes slower then before.Does e-brake use brake fluid?I cant barely see the brake fluid max.
    Aug 27 2013
    Philly
    Quote Originally Posted by Cluzsan View Post
    Parking brake is 100% cable actuated. If he was really riding the clutch to get the car going I could see the clutch getting glazed.Otherwise, 1.5 miles really isnt that far.
    Apr 13 2016
    Belleville NJ
    Yea isn't that much far,but the clutch feel loose,the pedal feel like there not enough much pressure.It goes into all gears fine.Wonder if it the slave
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Depending on how low the brake fluid reservoir is, you may have air in the clutch hydraulics, which would give a spongy pedal.
    Apr 13 2016
    Belleville NJ
    So spongy pedal don't have nothing to do with glazed clutch?Read your JHM tuned nice I too do a lot of trips but the JHM Clutch is very expensive.
    Dec 28 2006
    Western Maryland
    Low brake fluid should not affect the clutch operation. Even if you boiled the brake fluid at the calipers it would not affect the clutch operation. The clutch hydraulics has a separate open top reservoir built into the brake master cylinder reservoir. The opening is set at approximately half the depth of the brake master cylinder. Consequently you could bleed out all of the brake fluid and the clutch would still operate. Conversely you could bleed out the internal clutch reservoir and still have brakes. A built in safety feature.
    If you are now getting a slight clutch shudder under acceleration and you didn’t have it before that is a pretty good indication that you damaged the clutch disc face. What you are feeling is a grab/release/grab /release when under load.
    Apr 13 2016
    Belleville NJ
    Ok Good explanation ,Would I have to replace the Flywheel?if so Dual Mass,Conv Kit or Single?Thinking on going with Valeo other then that is too expensive
    Dec 28 2006
    Western Maryland
    As long as the symptoms only occur under high load I would recommend driving the car as is and treat the clutch as gently as possible. If the glazing is only on the surface you may be able to work through it. If the symptoms persist or get worse the Valeo kit is probably going to be your most cost effective option.
    I do have one question. If I attempt to drive with my parking brake engaged I get a red brake warning light. If i drive more than a few feet I also get an audible warning from the display. Was your warning system not working?
    Apr 13 2016
    Belleville NJ
    I didn't drove it,But I just try again and no there no brake warning light on and no audible from the display there supposed to be a circle with an exclamation mark and two parentheses.Wonder why it doesn't work is a 2005 suppose to have the latest revision.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    The the parking brake is engaged there is a red light on the dash the reads "BRAKE".
    Dec 28 2006
    Western Maryland
    There is a position switch on the back of the parking brake handle. Perhaps yours is unplugged? It should be clearly visible if you remove the rear ashtray.
    Mar 02 2015
    miami
    doesnt the e brake light come on when u start moving and its in motion? i know it does in my 02 when i move just a little with it up
    Apr 17 2016
    kc
    Put a new clutch in and be done with it!. It wont ever drive right again so either do something about it or deal with it. We cant really make it any better over the interweb!! , in the mean time pimp slap your stupidass friend for being an idiot and make him cough up some money!!!
    Apr 13 2016
    Belleville NJ
    I will be replacing it I don't like when things doesn't feel the same unless is better.The Red Brake light work , I though there was another indicator flashing when the e brake on and you driving.Thank you
