Results 1 to 24 of 24
    May 18 2012
    2005 S4
    Portland, OR
    Cruise control not working
    The cruise control is not working on my 2005 B6 S4. I checked the clutch, brake, and actual CCS switches with VCDS and they are all functioning normally. Turning on cruise control does nothing and the CRUISE light does not come on in the dash. It has worked in the past just fine. Any ideas?
    Senior Member Three Rings scottkollig's Avatar
    Nov 12 2015
    Delray Beach, FL
    Vcds might not pick up a faulty clutch pedal switch. I would swap that out, as it is likely it. It's a cheap fix.
    The most dangerous phrase in your vocabulary is "good enough".
    DTM 08' S4
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Quote Originally Posted by 924Carrera View Post
    Is your car tuned?
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    May 18 2012
    2005 S4
    Portland, OR
    Quote Originally Posted by Lucca M View Post
    Is your car tuned?
    Nope, all stock.
    May 18 2012
    2005 S4
    Portland, OR
    Quote Originally Posted by scottkollig View Post
    I was thinking that. Odd that it would show it actively switching on and off as I pump my foot on it, but whatever.
    Nov 12 2015
    Delray Beach, FL
    Yeah, mine did the same thing a few months back. I swapped it and it worked out despite my doubts. Hope it works out for you, I know how annoying it can be to not have cruise control.
    DTM 08' S4
    Veteran Member Three Rings NYC_Legacy's Avatar
    Oct 14 2009
    AZ/NY
    Thats what my issue was. Easy fix. Also the revs fell off quicker afterwards as well.
    "Brake last, finish first."
    Veteran Member Four Rings PetrolDave's Avatar
    Jan 14 2007
    SOLD: 2006 B7 RS4 Avant
    Hampshire, U.K.
    Quote Originally Posted by NYC_Legacy View Post
    Hanging revs and non-functional cruise are the two indicators of a faulty clutch switch.
    May 18 2012
    2005 S4
    Portland, OR
    Quote Originally Posted by PetrolDave View Post
    Yeah I have read that a few times, but haven't noticed the hanging revs issue on mine.
    May 18 2012
    2005 S4
    Portland, OR
    I replaced the clutch switch with the new updated one. Cruise control is still completely inoperative. Is it possible it needs to be re-enabled with VCDS? I had the ECU disconnected from battery for about a month. The cruise control worked prior to that.
    Jan 14 2007
    Hampshire, U.K.
    Check for fault codes on both the engine ECU and the SCSM (steering column switch module) with VCDS.
    May 18 2012
    2005 S4
    Portland, OR
    Already said and done, all modules of the car have been scanned a few times during this process and have no stored codes.
    Jun 28 2016
    Glasgow
    Same happened to me, must be common. I also had the brake switch go as the brake light wouldn't go off.. Did you touch the plunger part in any way? Like pushing it or or out etc before you installed it? They are very easy to damage. I'll try find the guide I used and post it if you want? Also is the car idling differently when at the lights etc? If so then it's defo the switch
    May 18 2012
    2005 S4
    Portland, OR
    Quote Originally Posted by Alanmc888 View Post
    It actually does have an idle issue that I still haven't been able to fix, but it does it whether or not the brake is applied. HOWEVER, as for the cruise control, I poked around some more in VCDS, verified that everything in the switch was reading correctly, then went for a drive and it works now...so who knows. I have CC back though, so that's nice.
    Jun 28 2016
    Glasgow
    Good stuff :-)... As for the idling problem. Is it just happening as you about to stop like foot off clutch, stop and then revs climb?
    May 18 2012
    2005 S4
    Portland, OR
    No, it's more of a random shuddering that shakes the whole car. Watching VCDS while it was doing it, 0 misfire count, no input or output fluctuations that corresponded with it. New spark plugs, ignition coils, and suction jet pump didn't help.
    Jun 28 2016
    Glasgow
    Could be a few things. Mines was doing it because the clutch switch.. Might be timing chain tensioner or even the intake manifold?.. Hope u get it sorted anyway mate as it doesn't sound too healthy
    May 18 2012
    2005 S4
    Portland, OR
    Yeah, whole timing job was done a few thousand miles ago. Intake flapper seems to be working, and as for the intake being loose, I just did valley pan gasket and check valves and torqued the manifold to spec with blue loc-tite. New PCV valve recently as well. New valve cover gaskets. New fuel filter. New MAF...LOL I have basically just thrown parts at this car (some for specific reasons, some just because why not) and it still keeps giving me headaches.
    Jun 28 2016
    Glasgow
    Engine mounts?... God knows mate, hope you get it sorted :-).... Might go away now the cc is working
    May 18 2012
    2005 S4
    Portland, OR
    Yeah I was thinking about doing engine mounts pretty soon just to see if it helps. Probably gut the downpipes too, as the car really seems down on power for no apparent reason.
    Jun 28 2016
    Glasgow
    Have you ever took the manifold off and gave everything a good clean? You have the 4.2 v8 in the s4 don't you?
    May 18 2012
    2005 S4
    Portland, OR
    Which manifold are you referring to? Yeah, that's the engine.
    Jun 28 2016
    Glasgow
    The intake manifold and ports and valves.. If it's the same fsi engine thts in mine (b7 rs4) then they get clogged with carbon. U probably already knew that anyway.. I'm getting mine cleaned today
    Senior Member Two Rings Malv1's Avatar
    Nov 23 2012
    1995 Volvo 850 T-5 R
    Rochester Hills, MI
    The S4 does not share the same 4.2FSI that is in the RS4. They have the regular 4.2 5v engine.
