Results 1 to 12 of 12
    Oct 10 2012
    san jose, ca
    recommendation for lowering springs
    Hi Everyone,
    I have a 2012 A4 Avant thats coming up on 65k miles and wanted to lower the car while i replaced the struts. i was wondering if you guys might be able to recommend a good set of lowering springs for the car? I don't think i need coilovers, since i am just looking to close the wheel gap that i have now. any help is greatly appreciated.
    Veteran Member Four Rings avantagg's Avatar
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Quote Originally Posted by garamvishal View Post
    Hi Everyone,
    If you're planning on replacing the struts and looking for a mild drop you should consider the Bilstein B12 pro kit. It's a nice set-up for a daily driver and really firms up the car.
    Recently installed this set-up on my avant and I'm very satisfied.
    2012 B8 Avant (3.0t Swapped)
    034 DP | APR UC | Ported Charger | Mertop Headers | Milltek Resonated Exhaust | Bilstein PSS-10 | Alu Kreuz | CR-15 | H&R Sways | 034 Inserts | Ecodes | A5 Cluster Swap | 3G+ MMI | RS4 FBSW | Black Headliner Swap | BUILD THREAD
    Veteran Member Three Rings BrewDude's Avatar
    Mar 13 2009
    04 R32 FT450
    KLAS
    KW H.A.S.
    Sent from my Nexus 5X using Tapatalk
    Veteran Member Three Rings Avantmaniac's Avatar
    Feb 21 2007
    2011 S5/2011 A4 AVANT
    Houston, TX, USA
    Mine on B12 also,
    - iKe -
    2011 S5
    2011 A4 Avant
    Oct 10 2012
    san jose, ca
    how much of a drop did you guys get on the b12 setup?
    Veteran Member Three Rings kdaffy's Avatar
    Apr 17 2014
    MA
    +1 on b12 kit....
    i second avantagg's opinion
    if you want adjustability go coilovers. PSS10 has great reviews
    Apr 17 2014
    MA
    I can measure my FTG tonight and let you know, but shortly after install I was at front ~25 3/4, rear ~26...
    Oct 10 2012
    san jose, ca
    Quote Originally Posted by kdaffy View Post
    THanks @kdaffy, i would greatly appreciate the measurements.
    also, is this the kit that you guys are referring to? https://www.ecstuning.com/Audi-B8_A4....0T/ES2983801/
    Apr 17 2014
    MA
    yes that looks like the one. Part number for avants is BIL 46-183354. ajusa (where I and others have purchased) is also another source, as it seems like ECS is out of stock
    Oct 10 2012
    san jose, ca
    thank you all for the help and recommendations.
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Good luck! Can't go wrong with Bilstein products. B12 on a budget PSS10 if you wanna go big :)
    Oct 10 2012
    san jose, ca
    Quote Originally Posted by avantagg View Post
    PSS10 would be a dream, but the boss (my wife) won't free up budget for them...
