Originally Posted by
OmaHahn
Having hard time believing this - proper fogs are low to the ground and on the corners of the car to light up the nearest pavement and edges of the road AND use YELLOW lights (scientifically proven for better lighting in inclement weather).
I live in a really dry state where most of our inclement weather is in the winter, and seeing as the car is so new I haven't had a chance to use them in the snow but in the rain, fog, and on normal nights you can actually tell that they are adding visibility, especially at night, they still are aimed low but cast a huge amount of light off the sides and below the headlights. And for cornering its night and day. I've never been able to tell when the cornering lights were on or not on my B8, especially when its a higher tier headlight with lower tier fog. Yellow may be better at creating more contrast but comparing the two different lights is just foolish, they are different beam patterns, lumens, and area covered. Yellow, is also the hardest color for our eyes to process and the most fatiguing, hence why it strains your eyes. Recreating daylight is going to be much more beneficial in inclement weather than having tinted lighting, scientifically. But either way, I notice a larger difference in the 'bad weather lights' I'll try to get a picture of them on vs off in the garage.
"However, in foggy conditions, the size of the water vapor particles is increased to the point where they are no longer of similar size to the blue light wavelengths, and are now of similar size to the yellow-orange-red wavelengths, and will tend to scatter and extinguish light in these bands, but will pass blue light.2"
LED's are still so new so there is very little research on them but there is more than just color at play, like the fact that the beam is coming from a fractionally smaller diode and creating less direct light to reflect. "the advantage that LEDs have in these conditions is the same advantage that they have in any circumstance, in that it is a directional emission source as opposed to a spherical one."
Here's an article from the
IMSA Journal
