Results 1 to 8 of 8
    Mar 06 2016
    2015 bmw m4
    kissimmee
    recommendation for a shop in Orlando to lower S4 B8
    Can anyone recommend a shop or someone that can lower my S4 B8 ? Thank you in advance!
    Better to have it and not need than to need it and not have it!
    Veteran Member Four Rings stereojorge's Avatar
    Oct 15 2013
    2014 Audi S4 P+ DSG, 2015 Audi SQ5 Prestige
    Tampa, Florida
    I have a fantastic one! But it's in Tampa. I definitely suggest the trip out here. I could speak volumes as to the quality of work and customer service!
    '14 Misano Red S4/APR Stage II+ DP ECU+TCU & UC/187mm Crank & AWE 57.55mm SC Pulleys/CMD Charge Chamber Intake/KW V1 Coilovers/EuroCode Sway Bars & AluKreuz/CR-15/034 Trans Mount/Apikol Rear Diff Mount/ECS Rear Diff Carrier Mounts/CMD Test Pipes/AWE Reso.Downpipes/AWE Track Exhaust 102mm Tips/Vossen HF-3 19" x 9.5"/Michelin PS4S'/StopTech Drilled Rotors/Akebono Euro Ceramic Pads/StopTech SS Lines
    Also: 2015 SQ5 Prestige | 2003 A4 Avant Quattro 6MT
    Previous: 2010 S4 P+ | 2008 A4 S-Line
    Mar 06 2016
    2015 bmw m4
    kissimmee
    Thank you! I will have to give them a call!
    Oct 15 2013
    Tampa, Florida
    Quote Originally Posted by boneymaroney View Post
    Email [email protected] Tell em I sent you from Audizine :)
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Down and dirty garage. Those guys are great. Real car lovers.
    +1 (407) 592-2569
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Mar 06 2016
    2015 bmw m4
    kissimmee
    Thank you! I appreciate all the recommendations 👍
    May 18 2016
    Orlando
    If you need VCDS in Orlando hit me up before I sell it.
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    Quote Originally Posted by Sofreshs5 View Post
    Let me know when you sell it, I might have interest...
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
