For sale is a kit for allowing the RS6 to mate with the 01E transmission.
Kit includes:
1. Steel flywheel (~20 lbs) which is designed to work with the clutch P/N for a 2.7T dual mass flywheel.
2. Custom starter, as the stock starter will interfere with he block (and no one wants to grind away material on the block that's pretty much exclusive to just the RS6)
3. Engine - Trans adapter ring that bolts up to the 01E prior to mating to the engine.
4. Hardware to be used in conjunction with a few of the stock bolts for mating the engine to the transmission. (In all, 13 bolts hold the engine and transmission together)
5. Detailed instructions.
All custom parts were professionally designed by 3D laser scanning teh RS6 block and 01E. Engine - Trans adapter and starter nose are CNC'd from 6061 aluminum.
$2250 shipped CONUS
Delivery within 1 week of payment
