Everything is stripped out of the way and the coolant is drained. I'm ready to tilt the radiator out of the way but I have an upper and lower metal tube attached on both sides of the radiator.
I'm sure the drivers side ones attach to the A/C rad since they connect at the front but the passenger side ones seem to bolt to the coolant rad as they're on the back.
Are the passenger side tubes that appear to bolt into the coolant rad safe to unbolt and remove?
BTW that one bolt on the underside of the bumper was a nice touch, way to bury a bolt under metal tubes you shouldn't disconnect Audi!
