Results 1 to 7 of 7
    Established Member Two Rings lapsandwich's Avatar
    Sep 28 2015
    Langley BC Canada
    Post clutch install, pedal travel sucks..
    brand new stock clutch and machined fly wheel installed successfully, but now the pedal travel feels wayyyy longer before it engages. ive only driven about 100kms, will this adjust over time as it breaks in ?
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    They machine too much off the fly?
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    Did you reset the SAC?
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Sep 28 2015
    Langley BC Canada
    I didn't check the SAC, but now I'm worried that could be the problem.. The car shifts amazing. It's just the pedal travel issue which has me now thinking it might be the SAC, but it doesn't have all the symptoms of out of adjustment ? I'm freaking out I don't wanna pull the trans back out..
    Jul 28 2009
    Philadelphia PA
    If you reused the pressure plate and didn't reset the sac you have problems my friend. Depending how much they took off the flywheel can help but...
    c8 a6 allroad
    Veteran Member Four Rings Dannydyn's Avatar
    Dec 20 2013
    Mercedes Benz ML350
    Cable?
    2014 S4 | 6MT | Estoril Blue | Lunar Alcantara | Rotors
    AWE S-Flo | Bilstein B8 | H&R OE Sport | RS4 Grille | 35% Tint
    Sep 28 2015
    Langley BC Canada
    I forgot the mention that, everything is brand new. Clutch, pressure plate, Tob. The new clutch should have been properly adjusted shouldn't it have ? How much would have had to be machined off the fly wheel for it to cause this. I don't fully understand how the sac works, but I'm under the impression it might tighten up after a few hundred miles of driving.
