Long time lurker here :) I can't seem to pinpoint what's going on with my car.
After a couple of miles (or kms) I get these errors. If I reset the codes, they come back after a few runs.
Anyone care to help out?
FIXED! UPDATE!
So while preparing to replace my injector and inspect the intake manifold for carbon build-up, I notied this piece that was leaking.
It's part of the brake system, it's a vaccum pump. It was leaking a lot. Had lots of oil on the radiator's return line.
I took it out with a Torx 30 wrench, albeit very diffcult to get to the screw underneath but it can be done without removing the entire bumper.
I've replaced both the O-ring and the gasket itself. Audi has since replaced this pump with a newer model but my pump, when turning it by hand, seem to work flawlessly.
The gasket: https://www.europaparts.com/vacuum-p...6e145215a.html
The o-ring: https://www.europaparts.com/vacuum-p...6d145117a.html
This might not be the correct dimension, but I can't find the right part number since the gasket didn't come with a plastic bag and a part number.
The pump itself, which I didn't change: https://www.europaparts.com/vacuum-pump-06e145100t.html
Good luck!
Code:
Mileage: 201810km-125398mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008)) Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAUEH78E87A046474 Mileage: 201810km-125398miles ------------------------------------------------------------------------------- Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl Part No SW: 8E1 910 559 F HW: 8E0 907 559 J Component: 3.2l V6 FSI 0080 Revision: --H19--- Serial number: Coding: 01040109190F0120 Shop #: WSC 93009 999 04862 VCID: 3169D31DA8FE1DB6C1-8064 4 Faults Found: 004376 - Oxygen (Lambda) Sensor Heating; B1 S2 P1118 - 009 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00000100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 27 Mileage: 201623 km Time Indication: 0 Freeze Frame: RPM: 768 /min Mass Air / Rev.: 109.0 mg/str Temperature: 91.5°C Idle Voltage: 13.87 V Bin. Bits: 00000010 008304 - Intake Manifold Tuning Valve (Bank 1) P2070 - 006 - Stuck Open - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 28 Mileage: 201623 km Time Indication: 0 Freeze Frame: RPM: 768 /min Mass Air / Rev.: 114.5 mg/str Temperature: 91.5°C Idle Absolute Pres.: 340.5 mbar Speed: 0.0 km/h 000611 - Fuel Injector #1 (N30) P0263 - 007 - Contribution/Balance Fault Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 40 Mileage: 201623 km Time Indication: 0 Freeze Frame: RPM: 768 /min Mass Air / Rev.: 109.0 mg/str Temperature: 91.5°C Idle Load: 15.7 % Speed: 0.0 km/h 004407 - Fuel Trim: Bank 1 (Add) P1137 - 007 - System too Rich - MIL ON Freeze Frame: Fault Status: 10100010 Fault Priority: 6 Fault Frequency: 3 Reset counter: 40 Mileage: 201710 km Time Indication: 0 Freeze Frame: RPM: 768 /min Mass Air / Rev.: 169.0 mg/str Temperature: 91.5°C Idle Time: 1433.6 s Bin. Bits: 00000010 Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09L-927-760.lbl Part No SW: 8E1 910 156 L HW: 09L 927 156 B Component: AG6 09L 3,2 FSI USA 0010 Revision: --H01--- Serial number: 4207022 Coding: 0000002 Shop #: WSC 06335 000 00000 VCID: 306FD619A3F414BECE-8064 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-910-517.clb Part No SW: 8E0 910 517 J HW: 8E0 614 517 BH Component: ESP8 quattro H06 0140 Revision: 00000000 Serial number: 00000000000000 Coding: 0004532 Shop #: WSC 06335 000 00000 VCID: 2E53C861B9C0024EDC-807A 1 Fault Found: 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 4 Reset counter: 24 Time Indication: 0 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x4202 Hex Value: 0x0024 Hex Value: 0x0193 Hex Value: 0x0001 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 BM Component: A4 Klimaautomat 2833 Coding: 00000 Shop #: WSC 00000 VCID: 6DD10F6D2746B956A5-5106 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl Part No: 8E0 907 279 N Component: int. Lastmodul USA 0907 Coding: 01023 Shop #: WSC 06335 VCID: 3D71FF2D37A6E9D655-4B00 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-94.lbl Part No SW: 8E0 959 655 H HW: 8E0 959 655 H Component: Airbag 9.41 H12 3840 Revision: 91H12384 Serial number: 0036N0023U5T Coding: 0033607 Shop #: WSC 06335 000 00000 VCID: 3C77F2297FBCE0DE62-8068 Subsystem 1 - Serial number: 6332DRB4039A46AC. Subsystem 2 - Serial number: 6342DRB4039D4F9D7 Subsystem 3 - Serial number: 6352ARB40162AD0FT Subsystem 4 - Serial number: 6362ARB4016018177 Subsystem 5 - Serial number: 63729RB40173B171E Subsystem 6 - Serial number: 63829RB40173B181G 2 Faults Found: 01212 - Belt Tensioner Igniter; Rear Passenger Side (N197) 001 - Upper Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 39 Time Indication: 0 01316 - ABS Control Module 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 2 Fault Frequency: 2 Reset counter: 39 Time Indication: 0 ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 Q Component: Lenksáulenmodul 0701 Coding: 04141 Shop #: WSC 06335 VCID: 418983DD4B5E8D3631-4AE8 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl Part No SW: 8E0 920 901 E HW: 8E0 920 901 E Component: KOMBI+WFS 4 H14 0110 Revision: 0110 Serial number: 00000000000000 Coding: 0023361 Shop #: WSC 93204 999 83903 VCID: 275D3D45953A53061F-5124 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl Part No SW: 8E0 920 901 E HW: 8E0 920 901 E Component: KOMBI+WFS 4 H14 0110 Revision: 0110 Serial number: 00000000000000 Coding: 0023361 Shop #: WSC 93204 999 83903 VCID: 275D3D45953A53061F-5124 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl Part No: 8E0 959 760 Component: Sitzmemory R2 F 0305 Coding: 00002 Shop #: WSC 00000 VCID: 71E9131D3B7E5DB681-4AE8 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 CG Component: Komfortgerát T7B 4135 Coding: 11820 Shop #: WSC 06335 VCID: 78FF2E3958040CFE46-4AE8 Subsystem 1 - Part No: 8E1959801G Component: Tőrsteuer.FS BRM 0706 Subsystem 2 - Part No: 8E1959802G Component: Tőrsteuer.BF BRM 0706 Subsystem 3 - Part No: 8E0959801E Component: Tőrsteuer.HL BRM 0606 Subsystem 4 - Part No: 8E0959802E Component: Tőrsteuer.HR BRM 0606 7 Faults Found: 00962 - Alarm via. Tilt Sensor 35-00 - - 01369 - Alarm triggered by Hood Switch 35-00 - - 01374 - Alarm triggered by Terminal 15 35-00 - - 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - 01572 - Alarm triggered by Door Contact Switch; Passenger Side 35-00 - - 00955 - Key 1 35-10 - - - Intermittent 00956 - Key 2 35-10 - - - Intermittent ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4F0-910-357.lbl Part No SW: 4F0 910 357 F HW: 4F0 907 357 F Component: AFS 1 H01 0020 Revision: 00000001 Serial number: Coding: 0000019 Shop #: WSC 06335 000 00000 VCID: 29593B7D802E657609-807C Subsystem 1 - Part No: 8E0 941 329 A Component: AFS-Modul links H03 0010 Subsystem 2 - Part No: 8E0 941 329 A Component: AFS-Modul rechtsH03 0010 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 8J0-035-1xx-56.clb Part No SW: 8E0 035 195 AC HW: 8E0 035 195 AC Component: R Symphony2+ H02 0070 Revision: 00H02000 Serial number: AUZ1Z4F2825142 Coding: 0610112 Shop #: WSC 06335 000 00000 VCID: 68DF7E7958A49C7ED6-5140 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 8P0-862-335.lbl Part No SW: 8P0 862 335 J HW: 8P0 862 335 J Component: FSE_255x BT H21 0290 Revision: 00000001 Serial number: 00000000497438 Coding: 0001677 Shop #: WSC 06335 000 00000 VCID: 3D71FF2D67A6E9D655-5124 No fault code found. End-------------------------(Elapsed Time: 07:12)--------------------------
