Results 1 to 7 of 7
    Aug 31 2011
    C7 A6 3.0T Prestige - AEV JKUR
    Lathrop
    Thumbs up NOW AVAILABLE: JHM B6-B7 Pre-Built Complete Rear LSD Differential Assemblies!
    Hey Everyone!!
    JH Motorsports is excited to now offer the JHM Rear LSD Pre-Built Rear Differential Core Program. Installing a rear LSD can be simple work, if you have experience and the variety of tools required to properly install an LSD into a rear differential. However, a majority of people do not have that luxury which is why we now offer the JHM LSD Pre-Built Rear Differential Core.
    What is a Pre-Built Rear Differential Core? A pre-built core is an OEM Rear Differential that we have pre-installed our JHM Helical Rear LSD into here at JH Motorsports, meaning the customer does not need to perform any specialty work to have our JHM Helical Rear LSD installed in their car. All the customer will need to do is a simple swap of rear differentials and they are ready to hit the road with their new found grip.
    Since this is a core program, you will be receiving a Good Used OEM Rear Differential in exchange for yours. We inspect all differential cores when they come in to make sure they are in good working order before they are rebuilt (Some cores may look different than your original differential due to different locations and weather climates). During the installation of the JHM Helical Rear LSD we will also refresh the differential with all new Ringer Gear Bolts, Seals, and O-rings! ALL JHM Rear LSD Pre-Built Rear Differential Cores will come with a 12 Month Limited Warranty as well as a Limited Lifetime Warranty on the LSD itself.
    Click HERE to locate the correct JHM Pre-Built Rear Differential Assembly!
    After years of research and development, we are proud to offer our JHM Helical Rear Limited Slip Differential LSD for the Late B6-B7 A4-S4-RS4
    In the stock Audi rear differential, the torque from the motor that's sent to the driveline is evenly divided between the two rear axles. In most driving situations this is normally fine. However, in cases where traction is lost at one wheel (i.e. under hard acceleration out of a corner or launching from a stop) power is only being sent to the spinning wheel. In these situations, a gear-based limited slip differential will take the torque from the wheel that's starting to spin and send it back to the wheel with that's not - the one with better traction. This means that both rear tires will spin together - with or without traction.
    Features and Benefits of the JHM Helical LSD:
    - Helical gears respond to changes in traction conditions very quickly
    - Improves traction and predictability of vehicle behavior: both rear wheels will spin at the same rate. Under hard acceleration out of corners or launching from a stop the car will either "hook up" and go or both rear tires will spin. Some "track focused" drivers say that this allows you to steer the car better with the throttle.
    - Prevents "one-legging" (spinning one rear tire only) and therefore eliminates losses in acceleration under load out of corners and heavy acceleration from a stop (launching).
    - Maintenance free! There are no clutch packs to replace as they wear out.
    - No special gear oil or additives necessary. Again, since there are no clutches, you can run the same gear oil as recommended by Audi in our LSD.
    - Our JHM Helical Rear LSD comes with a Limited Lifetime Warranty against manufacturer defects.
    While we recommend our LSD for anyone looking to improve the traction and predictability of their quattro Audi, the more horsepower your car has or the harder you drive, the more our JHM LSD will make a difference in your car.
    Click HERE for JHM Helical Rear LSDs!
    If you have any questions or would like help placing your order, please don't hesitate to contact us!
    [email protected]
    209-968-0077
    Jake
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    one day ill ordered one of these.
    2008 Audi A4 2.0T
    320awhp/420awtq...E85---UnitedMotorsports Tuned
    2015 A3 8v P-Stock
    2003 A4 Avant 3L-sold
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    i need this, and 4:1 centre diff. Then more track days.
    Stage 2 Banner Advertiser Four Rings Tech/Sales@JHM's Avatar
    Jun 04 2008
    The Fastest Audis
    California
    thanks for the orders everybody! keep them coming!
    Dec 23 2011
    Do you have lsd assemblies for the 2008 design yet?
    Veteran Member Four Rings RoguesGambit's Avatar
    Dec 19 2012
    Eatontown, NJ
    Definitely on my wishlist
    JHM St2 w/HPFP, JHM HFC+B7 S4 FI Catback, JHM St1 Clutch/Flywheel, S4 Recaros, JHM Shift-Trio+Cross Rod, Bi-xenon Headlights, JOM Smoked Tail Lights, Enkei PF01, Conti DWS, Solo-werks S1 Coilovers
    More to come
    Also, my story: https://www.amazon.com/Sage-Mike-Fra...7646774&sr=1-1
    Jun 04 2008
    The Fastest Audis
    California
    Thanks for all of the orders! Let us know if you have any questions
