Results 1 to 10 of 10
    Aug 31 2011
    C7 A6 3.0T Prestige - AEV JKUR
    Lathrop
    Thumbs up NOW AVAILABLE: JHM B6-B7 Pre-Built Complete Rear LSD Differential Assemblies!
    Hey Everyone!!
    JH Motorsports is excited to now offer the JHM Rear LSD Pre-Built Rear Differential Core Program. Installing a rear LSD can be simple work, if you have experience and the variety of tools required to properly install an LSD into a rear differential. However, a majority of people do not have that luxury which is why we now offer the JHM LSD Pre-Built Rear Differential Core.
    What is a Pre-Built Rear Differential Core? A pre-built core is an OEM Rear Differential that we have pre-installed our JHM Helical Rear LSD into here at JH Motorsports, meaning the customer does not need to perform any specialty work to have our JHM Helical Rear LSD installed in their car. All the customer will need to do is a simple swap of rear differentials and they are ready to hit the road with their new found grip.
    Since this is a core program, you will be receiving a Good Used OEM Rear Differential in exchange for yours. We inspect all differential cores when they come in to make sure they are in good working order before they are rebuilt (Some cores may look different than your original differential due to different locations and weather climates). During the installation of the JHM Helical Rear LSD we will also refresh the differential with all new Ringer Gear Bolts, Seals, and O-rings! ALL JHM Rear LSD Pre-Built Rear Differential Cores will come with a 12 Month Limited Warranty as well as a Limited Lifetime Warranty on the LSD itself.
    Click HERE to locate the correct JHM Pre-Built Rear Differential Assembly!
    After years of research and development, we are proud to offer our JHM Helical Rear Limited Slip Differential LSD for the Late B6-B7 A4-S4-RS4
    In the stock Audi rear differential, the torque from the motor that's sent to the driveline is evenly divided between the two rear axles. In most driving situations this is normally fine. However, in cases where traction is lost at one wheel (i.e. under hard acceleration out of a corner or launching from a stop) power is only being sent to the spinning wheel. In these situations, a gear-based limited slip differential will take the torque from the wheel that's starting to spin and send it back to the wheel with that's not - the one with better traction. This means that both rear tires will spin together - with or without traction.
    Features and Benefits of the JHM Helical LSD:
    - Helical gears respond to changes in traction conditions very quickly
    - Improves traction and predictability of vehicle behavior: both rear wheels will spin at the same rate. Under hard acceleration out of corners or launching from a stop the car will either "hook up" and go or both rear tires will spin. Some "track focused" drivers say that this allows you to steer the car better with the throttle.
    - Prevents "one-legging" (spinning one rear tire only) and therefore eliminates losses in acceleration under load out of corners and heavy acceleration from a stop (launching).
    - Maintenance free! There are no clutch packs to replace as they wear out.
    - No special gear oil or additives necessary. Again, since there are no clutches, you can run the same gear oil as recommended by Audi in our LSD.
    - Our JHM Helical Rear LSD comes with a Limited Lifetime Warranty against manufacturer defects.
    While we recommend our LSD for anyone looking to improve the traction and predictability of their quattro Audi, the more horsepower your car has or the harder you drive, the more our JHM LSD will make a difference in your car.
    Click HERE for JHM Helical Rear LSDs!
    If you have any questions or would like help placing your order, please don't hesitate to contact us!
    [email protected]
    209-968-0077
    Jake
    Nov 10 2015
    Sudbury, ON
    If only I had enough power to do dry pavement donuts! I would love this product, but $800US plus shipping. $1500 later :(
    2004 Audi A4Q 1.8T Ultrasport 6MT
    Frankenturbo'd, Meth, front mount, custom tune, full exhaust, bunch of other crap
    2004 Audi A4 Quattro 1.8T Tip Sport Pkg SOLD
    18" S4 Avus wheels l Eibach Lowering springs l Magnaflow 16601 l 3" TP l Pioneer Double Din l USP Bumper/S4 Door blades/Spoiler l Black on Black
    Senior Member Two Rings G-Ride's Avatar
    Dec 16 2008
    Imola 2003 A4 1.8TQ 5spd
    Melbourne Australia
    Thats' boss.
    Imola Yellow '03 A4 Quattro 1.8T 5 Speed
    :: Motoza Performance Tuned on e85 ::
    : Frankenturbo F21-L : Bosch EV14 750cc Injectors : 3" MAF : Milltek Turbo Back Exhaust : AudiSport Suspection : ER FMIC : Sachs RE Clutch : TyrolSport Brake Kit : StopTech & Ferodo DS2500 : Goodridge SS Lines : Forge 008 : 034 SD Engine & Trans Mounts : Apikol Snub & Rear Diff Mount : Podi & VEI Digital Boost Gauge :
    Established Member Two Rings shahk62's Avatar
    Jul 14 2015
    Sydney
    Any tiptronic versions coming ?
    2005.5 B7 A4 2.0T Quattro - 034 RSB + End links, GFB DV+, 034 Snub, 034 Billet Rear Diff Carrier Mounts, BSR CAI
    Aug 26 2005
    Quote Originally Posted by shahk62 View Post
    Since it involves the rear diff, the availability of a tip LSD depends on JHM having a tip final gear ratio core on hand to convert to LSD.
    Vorsprung durch Technik
    Senior Member Three Rings Pswish's Avatar
    Mar 25 2016
    2010 Suzuki VStrom 650
    Bay Area
    As in...drive all the way out there? lol. A remote office would be nice in El Cerrito/Albany/Richmond for the NorCal folks to avoid all that traffic.
    Veteran Member Three Rings cmiguel32's Avatar
    Aug 13 2007
    2003 A4 / 2014 S4 / 2017 Q5
    NC
    I wanted one of these when I purchased your 01E rebuild. Damn build budgets.
    Soon!
    Chris
    B6 A4: 2.0 stroker, IE cams, JHM 01E/Stg4 RS4 clutch/FW, SEM manifold, EFR7163, Motoza, ID1050x, Walbro 450, Garrett FMIC, 034 mounts/RSB, Koni coils, Hotchkis FSB, 18z, VFIZ, etc.
    B8.5 S4: EPL DP 57/187 (E40), 75mm TB, Ported SC, Meth, Autotech HPFP, Killer Chiller, Borla Exhaust, Merc HX, JHM SS/3R/Race pipes, Eurocode Sway, 034 springs, CR15
    429 whp/431 wtq 93 oct (stock TB)
    Insta: QuattroNC
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Quote Originally Posted by Pswish View Post
    Would be nice but highly doubtful. Most tuning shops have very few locations. I'd like to make the drive too some day. Maybe this summer.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Stage 2 Banner Advertiser Four Rings Tech/Sales@JHM's Avatar
    Jun 04 2008
    The Fastest Audis
    California
    Thanks for all of the orders! Let us know if you have any questions
