Results 1 to 14 of 14
    Aug 31 2011
    C7 A6 3.0T Prestige - AEV JKUR
    Lathrop
    Thumbs up NOW AVAILABLE: JHM B6-B7 Pre-Built Complete Rear LSD Differential Assemblies!
    Hey Everyone!!
    JH Motorsports is excited to now offer the JHM Rear LSD Pre-Built Rear Differential Core Program. Installing a rear LSD can be simple work, if you have experience and the variety of tools required to properly install an LSD into a rear differential. However, a majority of people do not have that luxury which is why we now offer the JHM LSD Pre-Built Rear Differential Core.
    What is a Pre-Built Rear Differential Core? A pre-built core is an OEM Rear Differential that we have pre-installed our JHM Helical Rear LSD into here at JH Motorsports, meaning the customer does not need to perform any specialty work to have our JHM Helical Rear LSD installed in their car. All the customer will need to do is a simple swap of rear differentials and they are ready to hit the road with their new found grip.
    Since this is a core program, you will be receiving a Good Used OEM Rear Differential in exchange for yours. We inspect all differential cores when they come in to make sure they are in good working order before they are rebuilt (Some cores may look different than your original differential due to different locations and weather climates). During the installation of the JHM Helical Rear LSD we will also refresh the differential with all new Ringer Gear Bolts, Seals, and O-rings! ALL JHM Rear LSD Pre-Built Rear Differential Cores will come with a 12 Month Limited Warranty as well as a Limited Lifetime Warranty on the LSD itself.
    Click HERE to locate the correct JHM Pre-Built Rear Differential Assembly!
    After years of research and development, we are proud to offer our JHM Helical Rear Limited Slip Differential LSD for the Late B6-B7 A4-S4-RS4
    In the stock Audi rear differential, the torque from the motor that's sent to the driveline is evenly divided between the two rear axles. In most driving situations this is normally fine. However, in cases where traction is lost at one wheel (i.e. under hard acceleration out of a corner or launching from a stop) power is only being sent to the spinning wheel. In these situations, a gear-based limited slip differential will take the torque from the wheel that's starting to spin and send it back to the wheel with that's not - the one with better traction. This means that both rear tires will spin together - with or without traction.
    Features and Benefits of the JHM Helical LSD:
    - Helical gears respond to changes in traction conditions very quickly
    - Improves traction and predictability of vehicle behavior: both rear wheels will spin at the same rate. Under hard acceleration out of corners or launching from a stop the car will either "hook up" and go or both rear tires will spin. Some "track focused" drivers say that this allows you to steer the car better with the throttle.
    - Prevents "one-legging" (spinning one rear tire only) and therefore eliminates losses in acceleration under load out of corners and heavy acceleration from a stop (launching).
    - Maintenance free! There are no clutch packs to replace as they wear out.
    - No special gear oil or additives necessary. Again, since there are no clutches, you can run the same gear oil as recommended by Audi in our LSD.
    - Our JHM Helical Rear LSD comes with a Limited Lifetime Warranty against manufacturer defects.
    While we recommend our LSD for anyone looking to improve the traction and predictability of their quattro Audi, the more horsepower your car has or the harder you drive, the more our JHM LSD will make a difference in your car.
    Click HERE for JHM Helical Rear LSDs!
    If you have any questions or would like help placing your order, please don't hesitate to contact us!
    [email protected]
    209-968-0077
    Jake
    Veteran Member Three Rings USAFS4's Avatar
    May 05 2008
    2008 Audi RS4; 2017 BMW M240xi Dinan stg 1
    PCC Potomac/Chesapeake
    Maybe dumb question, but does RS4 have a LSD? If not, C&D or Motortrend clocked this car as one of its fastest Slalom cars of all time (when originally tested), will this cause any trade offs in performance? Maybe I the car will improve in some handling categories but possibly worse in others. What say you JHM?
    2008 B7 RS4, Jackal Tune, w/JHM spacers and Flap Delete
    2012 B8 S4 Stg II APR. SOLD.
    2000 B5 S4 (Audry) Stg III: 390Hp & 435Tq. SOLD. Wish I kept it!
    Active Member Four Rings BenSti's Avatar
    Nov 03 2010
    Cupertino, CA
    Quote Originally Posted by USAFS4 View Post
    RS4 has open front and rear diffs from the factory. The rear LSD transforms the handling of the car, one of the most worthwhile mods in my opinion.
    2008 Audi RS4 Ibis White w/ Ti Package | 18x10.5 TCIII w/ 275/35 NT01 | PSI Raceline Ohlins | Stoptech Trophy Brakes F/R | Raybestos ST47 | OSGiken 1.5Way Rear LSD | Wavetrac Front LSD | Apikol Diff Mount | 034 Billet Subframe Bushings | 034 Motor Mounts | 034 Aluminum Trans Mount | 034 Spherical UCA | 034 Front Endlinks | JHM LWFW&Stage 4 Clutch | JHM Shifter+Linkage | Custom CAI | Custom Splitter | Hotchkis Sways F&R | Status Ring GT Seats + Half Cage | 034 Rear Endlinks | EBW LW Battery
    Mar 03 2014
    Sydney, Australia
    Do you make these for the B7 RS4 part Number 0AR500043T HNR?
    Senior Member Three Rings JoeyManhattan's Avatar
    Oct 04 2013
    '01 VW Passat B5, '92 MB 300E 2.6, '19 F150 Limited
    United States
    I'm curious as to how his would affect how effective the AWD is in say adverse conditions i.e. If I used her in snow again or heavy rain and water in the road. I feel like this would make her tail happy and a bit more touchy.
    2008 RS4 Mugello Blue Pearl, Silver Interior
    Aug 31 2011
    Lathrop
    Quote Originally Posted by MikeMike View Post
    Yes,
    pre-built: https://jhmotorsports.com/shop/catal...re-p-3952.html
    LSD: https://jhmotorsports.com/shop/catal...s4-p-3522.html
    Aug 31 2011
    Lathrop
    Quote Originally Posted by JoeyManhattan View Post
    It's a helical LSD, so if you are driving normally you will be fine.
    Mar 03 2014
    Sydney, Australia
    Jake, I get a product not found when i click on those links.
    Aug 31 2011
    Lathrop
    Clear your selected vehicle
    Oct 11 2007
    Suburbia
    Good point, I love the sure-footedness of the setup as is.
    12' R8 Daytona/CF V10 6MT
    07' RS4 Daytona/Panda
    Aug 31 2011
    Lathrop
    Quote Originally Posted by WinterRunner View Post
    If you drive correctly for the conditions, it will be as if nothing changed. If you decide to start romping on it in the snow you will get tail happy.
    Oct 11 2007
    Suburbia
    Romping in the snow is one of the the best things to do!
    Mar 11 2008
    B7RS4 & e46Ms
    With traction control on, it will perform the same as always. With traction control off, that's where it really shines. Audi should've put an LSD on these cars from the factory. It's the missing piece.
    FRRG AZ Ring
    Mar 03 2014
    Sydney, Australia
    That helped, Thanks.
    Whats the difference between your diff & the Wavetrac diff?
