Before measurements show a few things were out of wack. I had no odd wear on my old Michelin tires & car felt like it drove fine. The control arms were moved when he H&R OE's were installed. So I'm sure that factored in on things out of spec. He was able to adjust & fix most expect for its slightly out front camber wise. I'm not sure they could do this adjustment there, it was at a local Sears Auto which I trust over most of the kid filled auto shops around me.
Is this slight front camber "ok" with the H&R OE springs? Should I get it adjusted somewhere else? Btw he adjusted it for free and did it completely free of charge. I'd think I would need to go to someone like Audi to get the front camber perfect. He showed a diagram what needs to be done, something with involved shifting the whole system. He said it's only off by a tiny bit. Figured I'd ask you guys here and become more knowledgeable on this subject. Pretty sweet they did the adjustment they did free of charge. I ask so assume tire rotation every couple thousand miles will also help.
