Results 1 to 8 of 8
    Mar 05 2013
    CA
    "electric vacuum pump for brake servo" - delete?
    Any thoughts on this?
    I believe it came on AT cars, and takes up space in the bay.
    Is it now not worth having, and to be deleted, having swapped to manual?
    8E0 927 317A
    There's a rubber vacuum joint at the firewall.
    I noticed that the joint on a manual car, simply goes to the engine.
    Whereas the joint is a different part number for automatic, and has an extra port on it, to branch to the above Vacuum Pump via a hard line running under the coolant tank.
    In other words, is it as simple as swapping over the manual elbow? Will it matter to the cars computer/electronics?
    Dec 19 2011
    Colorado Springs
    I always wondered what that was...this actually pleases me to know I dont have it!!
    '12 GLI EFR 7163 - '16 S3 IE Stage 2
    Mar 05 2013
    CA
    "Only fitted to cars with tiptronic transmission"
    Here's a manual car without it:
    Dec 19 2011
    Colorado Springs
    I dont have anything in that big hole either.. I always wondered what it was, what went there..wtf it did.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    You really don't need it with the manual transmission. I would guess that you would probably get a few DTC's if you simply remove it. Something like an open circuit code.
    Veteran Member Four Rings MikeWire's Avatar
    Mar 08 2007
    Air and water
    SATX
    OP, I got your PM...found your thread.
    I pulled that aux pump out sometime after I did the trans swap.
    As far as a DTC, I either:
    a. Didn't care, since i had a CEL all the time anyway for SAI delete
    b. I possibly long coded it out post-swap via VCDS
    Do you have access to VCDS? If so, pull it and scan.
    If not, find someone who does have VCDS, bribe with beer, and scan :)
    -Mike
    @countdowngarage
    2015 Porsche Macan S | 2021 Atlas SEL-P | 1972 VW Bus | 1965 VW Beetle
    SOLD - 2017 VW GTI APR Stage 2
    SOLD - 2001 Allroad - 6 speed swap thread
    SOLD - 2003 A4 1.8TQM Avant Atlas - 5 speed swap thread
    Dec 28 2006
    Western Maryland
    A DTC for a disconnected brake vacuum booster pump probably would not result in a CEL since it wouldn't have any affect on engine emissions. It would only show up as a trouble signal if you scan for all codes.
    Mar 08 2007
    Air and water
    SATX
    Pre-swap, and a disconnected vacuum and/or electrical to the pump, one would get an ABS DTC, and ABS cluster light.
    You are of course correct OG, a DTC doesn't always trigger a CEL, but would be a stored fault.
    However, to avoid the DTC, that aux pump could just most likely be coded out using VCDS.
    And, the hose and check valve coming from the booster, to the input of the pump would need to be routed to the intake to provide the vacuum needed.
    I wish my memory was better, as I probably did just that, post swap.
    -Mike
    @countdowngarage
