Originally Posted by
Indskyz
Trim level is the Prestige model. I plan on lowering the car, but new to the Audi garage, so not sure yet who makes lowering springs or coil overs. I do not want to negative camber the wheels to prevent rubbing.
Someone correct me if I am wrong, it has been a while since I looked into this - but they don't make adj. control arms for the C6, so if you lower, you will add neg. camber and the front cannot be adjusted.
A little neg. camber is actually good for corner grip - it is the toe that will eat your tires alive if the the neg. camber is present. (Pro-tip: set toe to 0'. The steering will be a tad touchier and will have more difficulty tracking straight on highways, but handles better and saves lots of rubber $$)
As for myself:
Wheel Specs:
19x8.5 +38 with 255/19/35
H&R Springs:
Good quality // stock like ride quality // better cornering. At OEM spec (rear) camber I would rub over speedbumps and when hitting dips at speed when alone. If I had people or luggage in the car there was nothing I could do to not rub when hitting small dips // **Would still recommend**
ST Coils:
25 7/8" FTG [F] / 26" FTG [R] - Compared to HRSp, LOWER (idk) in front, .125" HIGHER in rear
Ride quality improved from H&R Springs (due to matched dampening rate, I assume) // I rub 0-5% of time solo and RARELY w/ 4 people (i did opt to adj rear camber, but only to like -1.9 (squared with my front, so not much at all). Although, I do rub while turning through dips at speed (front) on occation and was prone to laying the front bumper on the ground before understanding my height // **my preference from experience - would DEFINITELY recommend**
If you decide to go this route, I would be happy to give you some pointers for the ST's.
