Results 1 to 13 of 13
    Feb 15 2016
    Cambridge,Ontario
    contaminated A/C system ..
    Stinks to high heaven ..
    have sprayed Lysol in the air intake and had limited success. Anyone use any product they are happy with .?
    Also anyone happen to know where the AC drain port is under the car so I can make sure it is clean and not obstructed ?
    Thanks as always .
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Thanks as always .
    I usually use lysol myself and it does the trick... don't know too much about A/C systems but hopefully Phil chimes in... also, ironic user name eh? lol
    Oct 16 2008
    South Florida - Ft Lauderdale
    I used this on a customer car and it worked pretty well
    http://www.amazon.com/einszett-96110.../dp/B0002Z2MKO
    Phil
    Mar 24 2013
    Oakdale, CT
    Phil
    I used this about 2 years ago and it did the trick. The smell is starting to come back though, so it may be time for another can.
    -Adam
    Feb 05 2011
    A3 (sold), 2x B5 a4 avant (sold), b6 avant (sold), b7 avant (sold), b8 S4 avant swap. RS4 avant swap
    phila/PA/Northeast
    Have you changed you cabin filter recently? My a/c smelled bad and I changed mine and smell went away. Filter was all soggy and moldy from previous owner apparently never changing it.
    Veteran Member Three Rings Obsidian's Avatar
    Jun 16 2012
    '06 A4 2.0t
    Valley of the Sun
    Ozium... crank hi heat with the windows up and spray through where the cabin filter is in the engine bay. You can do either windshield or vent setting. I did vent and used like a half can, then turn on the recirculation setting and let it recycle the Ozium through the system for 15 minutes. Repeat if necessary but Ozium usually does the trick.
    2006 Audi A4 2.0T / 6MT / Brilliant Black
    APR stg II / 034 Motorsport / aFe / Avus
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2022 Kia Sorento; 2015 Ducati Monster 821 Dark
    Aurora, Colorado
    As stated above there's a cabin filter that should be changed every once in a while. Passengers side right below the windshield. You'll have to pull up the cover to get to it.
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    Quote Originally Posted by Hugh@EuropaParts View Post
    I came here just to say this, but you beat me to it.
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
    Feb 15 2016
    Cambridge,Ontario
    Thanks guys for the input. I'm thinking I have bacterial growth in the evaporator. Not sure if highh heat would solve that but il certainly give it a go as the Lysol just can't seem to get the job done.
    I replace my cabin filter whenever I replace my air filter on all my cars so no issue there.
    Back at it gents 👍
    1976 Yamaha XS 360
    Established Member Two Rings L'Audi's Avatar
    Apr 06 2016
    Long Island, NY
    Try the Ozium... spray a LOT of it with the system running/windows up (high heat as mentioned). Get away from the car. FAR FAAAAAR away and give it about 15-20 minutes.
    If that doesn't work, start looking for a carcass.
    06 Dolphin Gray tip 2.0T
    GIAC Xplus | USP Testpipe | RevMotoring Springs | 19X8.5/9.5 Niche Targa | pioneer 80PRS | Taramp's HD1200, HD8000, HD10000 | 18-Sound 6's | B&C 8's | Audiocontrol Three.1, Audiocontrol Epicenter | Clarion EQS746, MCD360
    Active Member Four Rings waiapasi2006's Avatar
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Phil
    I need to try this. Thanks for posting this Phil
    Waiapasi2006
    Account Terminated Four Rings
    Oct 15 2013
    Phil
    i used this and it works great. my AC got funky due to a damp underground garage.
    Oct 24 2015
    Perth, WA
    Its just IPA. You can get that stuff a lot cheaper. I would just change the filter to a carbon one. Will do the same thing ultimately.
    My respray thread
