    May 19 2016
    Wethersfield, CT
    Troubleshooting front wipers on c5 s6
    Howdy,
    My front wipers quit working on my s6. I removed the assembly and motor and it's moving freely, not seized up.
    I tried checking for power at the 4 pin connector going to the motor and saw no changes when moving the wiper switch.
    The rear wipers And front washers still activate just fine from the stalk control.
    Is there anything else it can be besides the wiper switch?
    Fuses are all good as well.
    Thanks in advance, applying rain-x on my front windshield to see is getting old!!
    2013 Audi A6 Prestige
    2002 Audi S6
    1995 Audi S6 (retired)
    Veteran Member Four Rings SteelyS6's Avatar
    Oct 29 2011
    Winnipeg Manitoba
    Similar problem as well, they started slowing down and then nothing. Lubed linkages and they are moving freely. Need to go in and check for power and possibly replace the motor. Hoping the one from allroad partout is the same.
    Jun 10 2013
    United States
    Check relay j31. Overly complex relay. Might be good to swap with known working unit.
    May 19 2016
    Wethersfield, CT
    Great, where is that relay located? Something I can pick up locally or is it a special relay?
    Thanks gents!
    2002 Audi S6
    May 19 2016
    Wethersfield, CT
    Relay it is! Thanks gents, couldn't get a clear determination if there was an external relay or if the function was part of another system, but all good now.
    2002 Audi S6
