Results 1 to 40 of 40
    Veteran Member Four Rings Willënskraft's Avatar
    Oct 14 2011
    2002 Audi A4 1.8TQ, 2007 Audi A4 2.0TQ
    Norcross, GA
    Is the timing belt suppose to be this loose?
    This morning I took the engine covers off and found the belt a bit loose on the top, but on the bottom it sits tight. However, yesterday after driving the belt was tight on all ends. Also I noticed that the belt sits near the edge of the cam gear and pushed it back in the middle this morning too.
    Video for reference
    "Beep beeeep bloop boop" - R2D2
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    That looks fine.
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Oct 14 2011
    Norcross, GA
    It does run normal, but wanted to make sure. Also, the belt was changed just last year.
    Veteran Member Four Rings MurkyRivers_A4's Avatar
    Dec 17 2009
    Tools, boxes of random car parts, 55 gal drum of used oil
    Kentucky
    You check the tensioner gap?
    2015 Daytona Grey Audi S4 | DSG
    2013 Ibis White Audi A4 | Tip
    2006 Brilliant Black A4 Titanium | 6 speed
    Apr 07 2011
    Looks normal to me.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Yeah, looks normal. The test is twisting it. Does it go past 90 degrees while twisting?
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Oct 14 2011
    Norcross, GA
    Looks normal to me.
    Quote Originally Posted by redline380 View Post
    It does look normal and just did the bend test. The belt didn't even bend 90 degrees, it was like this morning.
    Quote Originally Posted by MurkyRivers_A4 View Post
    Actually I used the new INA tensioners and no need for the 8mm gap(I think).
    Here's some pictures
    And this is with the front end off when the belt was finished last year.
    I think I might be worrying about nothing...
    Aug 26 2005
    It looks a little loose to me, the position of the notch in the back plate, should be positioned at about 1 o'clock. Loosen the pulley nut and use an Allen hex wrench in the hex hole in the hub to rotate the pulley hub clockwise until notch is at ~1 o'clock then tighten the nut. Then rotate the crank two revolutions and check the belt tension again.
    Vorsprung durch Technik
    Jun 30 2008
    Erie, Pennsylvania
    The "Litens" spring-loaded tensioner (roller) is not installed properly. The black bracket/arm is supposed to seat in the coolant freeze plug in the cylinder head. It may be slightly bent from being improperly installed in it's current position. It should probably be ok to bend back, but you will need to use your judgement. It is critical that it seats properly. If it "jumps out" of the freeze plug position during engine operation, the belt will loose tension immediately. Catastrophic engine damage could result.
    I would not feel comfortable starting this engine again. If I was to work on it, I would first disconnect the battery and then push it in the shop.
    Also: freaking EXCELLENT photos. Makes my couch-diagnostics much easier. lol
    Aug 26 2005
    Yes you are right. I just installed one of these tensioners and the notch will be about 1 o'clock with the tab in the freeze plug hole. If the nut is torqued properly to spec, the tab can't come out of the freeze plug hole.
    Jun 30 2008
    Erie, Pennsylvania
    Right. Normally it would never be able to come out. But as it has been fully installed with the bracket not seated in the freeze plug, it may have significantly bent the bracket. If he were to bend it back almost into position, but not FULLY, there could be a problem. It might just barely catch the hole and then pop out 1,000 miles later - possibly leading to catastrophic engine damage.
    The best advice would be to check it out carefully. If it is bent or damaged in any way, replace with a new part. That roller is available separately for $60-$80. OEM part number: 06A109243A
    Oct 14 2011
    Norcross, GA
    From my understanding is that, the tensioner will have to be repositioned ASAP? Now would I have to set both cam and crankshaft to TDC?
    Also, when you guys mention "notch" is that the hex key hole that's supposed to be set at 1 o' clock?
    Oct 14 2011
    Norcross, GA
    Updated pictures from the top on the tensioner and what looks like the notch which sits at 1 o'clock.
    Oct 14 2011
    Norcross, GA
    Hang on let me enlarge those pics.
    Dec 17 2009
    Kentucky
    Quote Originally Posted by Willënskraft View Post
    See this pic here, I believe they are saying that the black tab needs to be resting in the freeze plug on the head, which is at the 1 o clock position.
    Which can be seen here
    Oct 14 2011
    Norcross, GA
    So this is supposed to go here?
    Dec 17 2009
    Kentucky
    Not exactly there. See the freeze plug that your line that you just drew went through. That black tab with the 90 angle should rest in that freeze plug. It has the angle for that reason. What was stated earlier is since its not in the spot, the tab may be bent, which you shoukd be able to bend back if it is.
    If you move the tab into the position, the cut out on the tab will be in the 1 o'clock position
    Like so
    Oct 14 2011
    Norcross, GA
    Ohh ok I see. But would I need to set it a TDC?
    Aug 26 2005
    Like so
    This is correct.
    Dec 17 2009
    Kentucky
    Absolutely. Then once done setting everything, rotate the engine as diagnosticator had advised.
    Oct 14 2011
    Norcross, GA
    Just googled imaged 'b6 freeze plug tensioner', so this is what it's supposed to be?
    Dec 17 2009
    Kentucky
    Yours is the second pic and yes.
    Oct 14 2011
    Norcross, GA
    Actually I haven't done it yet, the pic is from Vortex lol.
    I'll have to tackle it first thing in the morning and post an update later.
    Also, mucho gracias for all the replies!
    Dec 17 2009
    Kentucky
    No problem. Glad the other guys chimed in cause I never would have noticed that lol.
    I just understood it when they explained it and helped guide you :)
    Aug 26 2005
    The engine does not need to be set to TDC to retension the timing belt since the timing for the crank and cam sprockets is already set. But it can't hurt to set the engine to TDC with the cam sprocket marks lined up, if you want to confirm correct timing.
    Aug 26 2005
    No, the notch is the 90 degree cut out in the black back plate.
    Aug 26 2005
    The positioning of the back plate tap in the freeze plug hole, is placed before the pulley hub is rotated clockwise to tension the belt.
    Oct 14 2011
    Norcross, GA
    Good morning guys! Just took the radiator support off and here's what I'm looking at right now.
    So here's the steps and correct me if I'm wrong.
    1) Remove radiator support
    2) loosen tensioner nut
    3) turn the black tab clockwise until it sits in the freeze plug hole
    4) use an allen bit to turn the tensioner is tight, then hand tighten the nut
    5) use torque wrench to set the nut at 27 Nm
    Oct 14 2011
    Norcross, GA
    I'll wait for a reply hehe
    Also, does anyone have pictures of your own finished tensioner?
    Oct 14 2011
    Norcross, GA
    I went ahead and did it, this is what I have so far. It's super tight, actually way tighter then before. Now before I tighten the nut, this is how it's suppose to look like right?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Review this: Clicky click®
    Oct 14 2011
    Norcross, GA
    Lol I was just reading that and I found the INA instructions paper.
    And here it is with the notch aligned with the ridge.
    What do you guys think?
    Dec 28 2006
    Western Maryland
    That now looks correct. Rotate the engine two revolutions clockwise and recheck the position. If it still looks like that you are good to go.
    Oct 14 2011
    Norcross, GA
    Had to make a slight adjustment, but after 2 revolutions it sits aligned . And now to put everything back together...
    Aug 26 2005
    You nailed it. There should be a flat washer under the nut. Thanks for the update!
    Oct 14 2011
    Norcross, GA
    Just test drove to NAPA for coolant, then rechecked everything. No leaks and car runs normal. Next is to do a TBA. I'll also make an update after one week.
    With front end
    Cover on
    Cover off
    Thanks again guys!
    Jun 30 2008
    Erie, Pennsylvania
    Nice work. Good on you for noticing the looseness, and having just the right amount of "ok panic" to get it resolved. And such excellent photos, I can't even.
    Oct 14 2011
    Norcross, GA
    Haha thank you! I actually took pictures of every step and not bad for a potato phone ehh.
    Jun 30 2008
    Erie, Pennsylvania
    ^I'm pretty sure it's the photographer. And all that Georgia sun can't hurt, either. ;)
    For any future readers, I'm pretty certain the fix in this thread can be achieved without pulling any of the front end off the car. Just popping off the upper t-belt cover should give adequate access to reposition and reset the spring-loaded Litens tensioner.
    Oct 14 2011
    Norcross, GA
    Did a couple of TBAs and repositioned the snub mount this week. Also, upon start ups it's more "tighter" lack of a better word and coasting seems to stay longer (could be my imagination lol), but overall it is good to go .
