Congratulations on joining the Family...
However, your first order of business with this RS6 is to go over its mechanical health in a close inspection. With 108k miles it more than likely needs a few replacements. So first check all coolant connections and all gaskets. Because of the immense heat in the engine bay of all performance Audi's, the connections to plumbing crystalize and begin to fail.... Next would be a check of the internals, as in leak down and compression tests. New plugs and coil packs are always a good idea.
Lubricants, motoroil and filter change, need to check if any residue is at the bottom of your oil pan, that will tell you if you need to look further inside the motor. @ 108,000 differential fluid replacement is also a good idea...
Now for the ciritcally important parts... V8 twin turbo's. (a) those twin screws need attention as to their condition... Both because if one is in need of replacement then both have to be replaced as they need to be matched... Here is one of your wallet draining potentials. (b) You have 2 intercoolers on each front side. Deleting those and installing an FMIC is not a good idea. You are not going to improve on Audi's engineering here. The RS6 was well thought out. There's more then plenty of cold air for the V8's requirements at a much higher HP setting...
Next would be suspension items. Might be a good idea to look into replacing all the rubber bushings with a harder urethane compound. Springs and dampers next. All control arms should be reviewed. Since we're down below... Brakes, you have Brembo's, may very well be time to up the performance by better pads and lighter rotors...
That's about it for the preliminary list.....
Make sure its healthy and up to spec, live with the car for a while and do some research in the RS6 Forum section....
Have fun but don't trash it by wanting to add A4 2.0T mods... There's only 1,200 of these in the USA ( 1,290 if you add Canada )
