Results 1 to 3 of 3
    Established Member Two Rings 1.8t's Avatar
    Jul 25 2008
    Timing Chain - Iwis
    Hey Guys/Girls,
    What do you guys think of the Iwis timing chain that europa and ecs sell? I'll be doing a timing overhaul, and plan to get the JHM basic kit that include all tensioners and the iwis chains if they're any good.
    If I do it this way i'll save a few hundred bucks which would help as I'm also doing the engine mounts, snub mount, clutch/flywheel, cam adjusters, valley pan gasket etc.
    Would be nice to save some coin.
    Sprint Blue/Black B7 S4 Avant 6MT - KWV3, Catless Downpipes, Miltek Resonated Catback, Revo Tune, Hotchkis F & R Sway Bars, Flat Bottom Steering Wheel, RS4 Pedals, Ocarbon Trim, Ecs Snub mount, Michelin Ps2, OEM S5 Rotor Wheels, 6 Piston Brembo Calipers.
    Veteran Member Three Rings SprintBlueWorld's Avatar
    Sep 16 2013
    08 Hemi Big Horn, 08 Honda civic, 08 Audi S4 Cab MT6
    Pa
    I've never heard a single trouble on these cars blamed on any of the timing chains specifically. Maybe their made of titanium or something. It's always the tensioners guides or adjusters that are far more likely to cause trouble.
    Oem RS4 Reps, RS4 Pedals, KN Air Filter, JHM 93 tune, JHM Intake Spacers, Rear Stoptech Slots & SS Brake lines, JHM 6-Rib Pullys, 034 Snubby Bracket, Dimple/ECS Oil & Diff Magnetic Drain plugs, Apikol Diff Mount, 034 Carrier Mount Inserts, Corsa RSC Cat-Back, 034 Sway Bar & End Links, Piggies in a Blanket, Front JHM LW Rotors, Hawk HPS pads, 13mm Spacers
    Jul 25 2008
    Quote Originally Posted by SprintBlueWorld View Post
    Yes i've never seen anyone blame the chains either, but i'm thinking if im doing the rest, why not the chains as well
    Other than jhm everyone sells iwis chains, im assuming they're good
