Results 1 to 8 of 8
    Aug 05 2011
    LI, NY
    Wanted - Sport Diff
    My car is a 2013 S5 and it didn't come with the Sport Diff. Curious as to what would it take to add it if at all possible. I'm guessing the rear diff itself but what all else is evolved? See cars being parted/sold all the time on Ebay and whatnot. I could easily do the work myself but just curious if it can be done and would it be worth it?
    Appreciated
    Bob
    2019 RS5
    2013 Audi S5 Estoril Blue - SOLD
    Weekend Warriors - '97 Mitsubishi 3000GT VR4 / '96 Mitsubishi 3000GT VR4 Spyder
    Veteran Member Three Rings TTRStud's Avatar
    Jul 12 2013
    Jacksonville, FL
    I believe there is an electronic component associated with it, which may require some sort of programming. It's not a mechanical LSD, so not as simple as swapping the one you have with a sport diff from another S5.
    '10 Meteor Gray Metallic S5 Prestige Loaded 6MT - AWE Track - PCed OEM Rotors
    Veteran Member Three Rings ParadigmTony's Avatar
    Apr 02 2015
    Rochester NY
    I can't find them, but I dug up the part numbers for this once. ITs not just a mechanical component unfortunately. Its an electronic controlled diff. You would need the whole assembly and controller. If I remember correctly though, you do not need a new ECU, as it will work with yours and can be coded in. Not much help, but its what I have for now.
    //B8 A5 // 6MT DSB Pearl // Roc-Euro // APR // AWE // BBS // Bridgestone // StopTech // // K04/Stage 3v3/FMIC/Roc-Euro Intake/Test pipe-AWE touring/100oct life/19x10 CI-R/RE71R/ST60 BBK //
    Veteran Member Four Rings UkuRiSh's Avatar
    Jan 09 2010
    New York
    gotta check wiring diagram to see what we need for the swap ! very interested to swap in my S5 too)
    2013 AUDI S5 4.0T SWAP 9.7@145mph < Press @svarog_performance < last test updates
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    I can almost guarantee it's going to require VAGCOM programming as well. I don't believe the sport diff. option even shows in MMI if the car isn't equipped for it, just like how Adaptive Suspension is.
    2013 Audi S5 - EPL Stg 2 ECU/TCU
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Jan 09 2010
    New York
    Quote Originally Posted by HazeMyth View Post
    Yes it's defiantly needs Recoding and adaptation true Vag-Com but shouldn't be a problem, I believe we can copy code from S5 with S/Diff and used.
    Aug 05 2011
    LI, NY
    I have VAG-COM so that wouldn't be an issue. Just would need to know what all components are needed. Rear Diff, Controller, Harness, Rear Axles? Would need to source all from one location as this would make things easier. From what I understand there's a switch for it that's under the DVD where the others are
    2019 RS5
    Jan 10 2008
    Roy, WA
    Bringing this thread back to life. I do love it in my RS5 and I've got a '13 S5 without it. But...I've got a '12 S4 with it that I'm parting out so I have all of the parts. I've heard ECU, Diff, axles, wiring and programming. Anybody know for sure?
    2003 RS6 (6Spd)
    2013 RS5 (Headers, Aluminum DSG Flywheel,JHM Stg2, etc...)
    2013 S5 (034 Stg2 & TCU)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
