I have all parts stock and some upgraded/
aftermarket. I'm selling the longblock, tranny,
suspension, exterior, interior, and everything.
Some fresh build parts as well. Everything located
in St.Lucie County, Florida. All payments sent as a
gift or add %5 for Paypal fees.
I'll start with the new performance parts &
some used. List below:
2. (Used) 2bennett A-pillar gauge pod in black & Autometer boost gauge (30 psi, white face, red needle, backlight)-
$125 Shipped
4. (Used) Genuine 710A diverter valve- $27 shipped within CONUS
Verified Working Condition.
7. (New, never used)- urS4 Euro headlight lenses- $125 shipped within CONUS
9. (New, never used)- TRW front control arms with AK Motorsports poly bushings- $214 shipped within CONUS
13. (New, never used)- Iroz 3" full v-band downpipe- $300 shipped within CONUS
25. Custom Black air leather with silver stiching E-brake handle- $50 shipped
26. Freshly made black leather E-brake boot- $30 shipped
29. (NEW) ACL non coated stock AAN main bearings & thrust bearings- $100 shipped OBO
30. Victor Reinz top end gasket reseal kit for AAN 20v 5cyl- $150 shipped- lots of gaskets
Now for the stock stuff:
1. AAN water manifold- $65 shipped
2. AAN fuel rail with braided line, FPR still on it and a newer bosch fuel filter- $100 shipped
3. Good Bosch starter- $57 shipped
4. Good Alternator- $64 shipped
5. AAN motor mount bracket set- $65 shipped
6. Good factory upper radiator hose- $40 shipped
7. Mint urs4 orange corner lights- $35 shipped
8. urS sedan outer tail lights/ok condition-- $64 shipped
9. Good 5 speed 01E will include it complete and with all new seals from dealer- $350 + freight shipping
Another good 5 speed 01E- $250 + freight
10. Good urS locking rear end- $150 + shipping via greyhound
11. Set of OEM urS axle cores- $250 + shipping for all 4 or $75 + shipping per axle
12. x2 OEM driveshaft cores- $65 + shipping via greyhound
13. OEM front brake calipers, carriers, hardware and brand new pads- $150 shipped within CONUS
14. Stock AAN flywheel- $100 shipped
15. Stock AAN K24 turbo very minor shaft play and one broken exhaust stud- $125 shipped
16. Stock AAN exhaust manifold- $100 shipped
17. ECRU rear seat back in good condition- $150 shipped via greyhound
18. Stock AAN wastegate & flexpipe- $100 shipped
20. Nice ECRU rear deck with good speaker grills- $150 shipped via greyhound
includes adapters for aftermarket 6x9 speakers
21. Old style 4 spoke black steering wheel with airbag- $25 + shipping
24. Box with every relay, fuse, and module from a 95.5 urs6- $125 shipped
25. Good 95.5 ABS pump- $125 shipped within CONUS
26. Good 95.5 ABS computer- $57 shipped within CONUS
Also have a 94 s4 abs computer- $57 shipped
31. AAN intake manifold- $150 shipped within CONUS
33. AAN throttle body with TPS- $57 shipped 1 left
34. AAN oil cooler assembly- $100 + shipping
35. AAN air box assembly- $75 + shipping
37. urs4 doors, no trims, (some rust)- $100 + shipping per door or $750 shipped for all 4 via greyhound
Very minor rust but overall in very good shape. Great for replacements
38. urs4 rear bumper in good shape, trims intact, just needs to be resprayed- $250 + shipping via greyhound-- includes all 3 trims and bumper shocks
40. Good set of ECRU door cards- $200 shipped via greyhound
41. Good set of 94' urS window motors- $125 shipped within CONUS
42. Mint brake master cylinder (Factory Genuine)- $107 shipped within CONUS
One is a 95.5 unit and another an early 94. I found out they are different.
44. USED 94' urs4 factory brake booster- $115 shipped
45. USED 94' urs4 clutch master & slave cylinder set - $115 shipped
Master is factory and the slave I have a factory boge unit
47. Good brake pedal- $50 shipped
48. Good gas pedal- $50 shipped
52. ZF factory rack & pinnion/suggest a rebuild but might
be able to get away with just a new boot & fluid-- $150 + shipping
54. rear knuckles/uprights- $50 + shipping for the set
55. Front subframe- $50 + shipping via greyhound
65. rear subframe- $50 + shipping via greyhound
66. urS black trunk good shape/just needs a respray- $200 + shipping
67. Fuel injector cover (Mint)- $65 shipped
71. urS 26mm front sway bar- $50 + shipping via greyhound
72. windshield wiper arms with good blades- $70 shipped
73. Clean windshield washer reservoir with good headlight washer and windshield pump-
$100 shipped---- includes pumps and plugs with wiring pigtails attached
74. power steering reservoir includes cap, sensor, and wiring pigtail- $65 shipped
75. Strut tower brace- $25 + shipping
76.Mint Strut tower covers/caps- $57 shipped
78. urs4 cluster in good condition- $150 shipped within CONUS
79. All interior buttons, switches, ETC- $65 shipped
81. Good charge piping hoses- $100 shipped within CONUS
OEM throttle body and turbo outlet hose. 2 out of the 3
82. Alright condition 17" 5 spoke A4 wheels that came on the car- with tires
$250 picked up or $200 + shipping via geyhound
85. Front Fender liner set- $100 + shipping within CONUS
86. stock urs4 headlights - lenses are foggy though- I will clean the lenses before shipping--
$125 shipped within CONUS update passenger side has broken tabs- make offers OBO
88. Good o2 sensor- $35 shipped I have 2 and one new universal
89. Good factory coolant tank hose comes with cap, sensor and plug with wiring pigtail- $50 shipped
90. Mint black rear view mirror- $57 shipped
93. Hood carrier locking carrier- $100 + shipping
94. Black mirror caps- $57 shipped
95. Complete good AAN engine harness- $250 shipped with CONUS
97. Good factory front strut mounts- $50 shipped for the set
98. Rear control arms- $100 + shipping
98. Rear toe arms- $50 + shipping
99. Stock rear diff mount- $40 shipped
100. Rear diff crossmember- $50 + shipping
101. whole center console switch board with all switches -- $100 shipped
102. AAN stock oil pump front flange- $107 shipped
103. AAN stock crank damper- $100 shipped
104. AAN valve cover- $75 shipped I have 2
106. AAN rear main flange in mint condition. Sand blasted and powdercoated silver- $50 shipped
107. AAN power steering pump bracket- $50 shipped
108. Idler pulley & accessory bracket- $100 shipped
109. clutch fan $40 shipped
110. Mint black urS rear bench seat- $150 + shipping
111. Nice black urS4 center console both pieces- $200 + shipping or $100 per piece
112. Nice black b-pillar trims- $100 + shipping
113. Nice black rear deck with black speaker grills- $165 shipped
114. Black dash pads pieces underneath & glovebox- $100 + shipping
115. Black door sills and kick panels- $100 + shipping
If there is anything you are looking for feel
free to contact me anytime. Don't be afraid
to make offers on certain things either the
worst I'll say is no or come back with another
number.
cheers
