Results 1 to 7 of 7
    Oct 02 2006
    Wadsworth,OH
    :: ECS Tuning :: Performance Rear Differential Mount | Audi B5 S4
    Your rear differential is the last stop in a spectacular sequence of powerful oscillations, gyrations, and vibrations - all in the pursuit of turning chemical energy into kinetic energy.
    This is only possible if the right parts receive the right forces.
    It's to this service that engine, transmission, and differential mounts are dedicated - and ECS Tuning engineers some of the best in the world.
    The ECS Rear Differential Mount for your B5 S4 is a product of countless hours of research and development, minimizing driveline deflection while maximizing strength.
    Engage
    Fits:
    Audi B5 S4 2000-2002
    Jason
    Aug 24 2014
    Newport Beach, CA
    I have this and I love it, ECS maybe you can include a piece of one sided foam to place between the mount and the chassis to reduce vibration? That's the only thing I'd change.
    Similar to this foam pad:
    2024 M3 Comp xDrive
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    Quote Originally Posted by christianb5s4 View Post
    Was also thinking about that! Was going to make one at work woth waterjet and some thin rubber
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by f4m0u5 View Post
    Pour some flex seal into a mold. Like the commercial. Bam rubber damper
    Aug 04 2014
    Gloucester MA USA
    Quote Originally Posted by vavJETTAw36 View Post
    Lol that would work
    Oct 02 2006
    Wadsworth,OH
    Unfortunately something that thin would not really have an effect on NVH transferred. The majority of the reason why you see a slight increase in NVH is not from where the mount contacts the chassis but because the denser material used for the bushing.
    Jason
    Aug 24 2014
    Newport Beach, CA
    Jason, I figured it won't cut down on NVH but more so the higher frequency vibrations that transmits through the mount directly into the chassis. I will try it and report back if for nothing else to see what happens.
    2024 M3 Comp xDrive
