Ok I have a B6 S4 and ended up replacing my cluster and comfort control module. My CCM was soaked in water and a bunch of stuff just was not working. So I replaced the module and everything seems to be working except my Speedometer, alarm horn, and lock for gas cap. My car also no longer lock doors at a certain speed. On the speedometer everything works except the speed reading and nothing updates on the menu screen on the speedometer itself. So no MPG, nothing is updating, not even the mileage. I hook the car up to vagcom and get no codes since replacing the CCM and I can see my wheel speed and vehicle speed in VCDS but my needle on the speedometer does not move. When I run the test in VCDS the cluster passes everything including needle sweep. So the only thing I can think of is Im not getting a signal from somewhere and I even have a new ABS module.
Any ideas would be greatly appreciated.
