I really hope that I'm posting this in the right place. I used the search and couldn't really find the answer I was needing. Okay so as I am new here I will start off by saying that thanks to your site I have learned so much about my first Audi. The car is an 04 A6 3.0 I'm having an issue with the radio, I have run the vag-com on the car and the only codes I'm getting is... I have checked both the fuse in the dash and the back of the radio and they are good. I'm getting no power to the radio, I pulled the plugs out of the radio and put a volt meter to each pin and the most I'm getting out of 2 different pins is 0.25 to 0.30 any help would be appreciated.
Address 16 Steering Wheel Labels 4B0-907-487.lbl
Part No:4B0 907 487 F
Component: Lenkradelektronik D01
Coding: 01005
Shop # WSC 02334
VCID: 2F630181EDEE9D46D7-515A
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 17: Instruments Labels: 4B0-920-xxx-17 lbl
Part No: 4B0 920 981 N
Component: KOMBI+WEGFAHRS. VDO D14
Coding: 02262
Shop#: WSC 24102
VCID: 316707F9FBDA8BB6C1-515A
WAULT64B34N027783
1 Fault Found
01304 - Radio
