Results 1 to 16 of 16
Thread: Flash Back....
    Active Member Two Rings jcopperthite's Avatar
    Nov 13 2012
    2013 S5, 2014 S6...gone but not forgotten
    Phoenix,AZ
    Flash Back....
    Does everyone do this or just roll the dice? I have a 2014 S6 with just over 11K on it and need to bring in for service...MMI says so. I had it APR tuned both ECU and TCU as well as a bunch of other stuff that i'm not to concerned with. Should I go to my APR shop and have them flash them both back to stock or just roll with it? Really just want real world experience/opinions here. I know if I get flagged it could cause a problem down the road but couldn't I lash back to stock at some point and deal with it then? Please let me know your thoughts.
    Thanks guys.
    Registered Member Three Rings DoughBoyFreshLV's Avatar
    Apr 02 2014
    Las Vegas, Nv
    Quote Originally Posted by jcopperthite View Post
    Thanks guys.
    Fash it back to stock my friend and save yourself the headache.
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    AKA: Yoshi123
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    If you take the car in for service with a tuned ECU, there is a high likelihood of it being flagged TD1.
    Some people don't care. It sounds like you do, so I'd recommend you flash back.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Four Rings VeryBadman's Avatar
    Jun 24 2012
    2017 BMW X1
    Bay Area CA
    Just flash back, there were stories regarding getting flagged despite flashing back to stock so it's not 100% guarantee that you will be fine but doing nothing is certain that you will.
    2020 ///M340i xDrive Mineral White Fully Loaded, IND Front Reflectors Delete Kit
    Remaining Parts: Neuspeed RSe102 19x9 et45 in Texas Grey
    Other: 2017 BMW X1
    Throwbacks: 2018 Audi TTRS, 2014 Audi RS7, 2013 Audi S6, 2011 Audi S4, 2008 Audi A4
    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by VeryBadman View Post
    Unless you are cool with you service advisor and your car doesn't need to be plugged in for any reason. Does your advisor know your car is tuned? Do you have a relationship with him?
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
    Jun 24 2012
    2017 BMW X1
    Bay Area CA
    Quote Originally Posted by Djpeaksd View Post
    I'm open about my car being tuned with SA but often it's the protocol from AoA that they have to hook the car up for certain operations so their hands are tied. My SA even recommend me to revert back to stock before service.
    We all want to think that personally relationship would get us off the trouble but you have to consider the very fact that after all they are still employee so they can't do us every favor.
    Other: 2017 BMW X1
    May 17 2012
    Houston, TX
    This keeps coming up and more conflicting experience comes up along with it.
    I used to flash by S4 back to stock before dealer visits to be safe. Then tried to only switch to stock program once because I was in a bind. No TD1. I think it depends on the dealer. You don't always need to plug in the car to AOA. If you have the time I would flash back to stock just to be safe.
    Nov 13 2012
    Phoenix,AZ
    Thanks everyone for your advise. I will Flash back before taking it in for service. Thanks again.
    Dec 18 2014
    DMV
    If your car needs to be plugged in then I would get it flashed back to stock. If its just routine maintenance and you're cool with the SA/Techs then you can take it in as is - my SA would let me know if they have to plug the car in.
    Sold: 15 S4, 16 Tornado Gray S6, 16 Glacier White RS7, 18 White Q5
    Current: Black SQ5, Black V10 R8
    Next: Gemera
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    I think I asked a while back and never got an answer, but no one is flashing back their TCU tune as far as I know. Are modifications to the TCU not detected by the spec actual?
    l 2013 S6 l Oolong Gray/Black l APR STG 2 l MILLTEK NON-RES l APR Downpipes l
    l 2022 Tesla Model S Plaid l Midnight Silver Metallic/Black l XPEL Stealth Wrap l
    l Hers: 2019 e-Tron Prestige l Manhattan Gray/Black l XPEL Stealth Wrap l Vossen HF-3 Gloss Black l
    Jan 30 2015
    2012 A6 3.0T Prestige + others
    Irvine/CA
    what service you need at 11k?
    - Michael
    2012 A6 3.0T Prestige:
    GIAC Dual Pulley 57.1+187 / Merc HX / Injen Intake / OEM muffler mod (Quad Tips + X-Pipe) / Eurocode drivetrain inserts / 034 Swaybar / Volk wheels / Bilstein+Eibach / RS front grill / Deval Carbon rear diffuser / Maxton Front Spoiler and Side Skirt add on / Carbon trunk spoiler / Carbon mirror / Stoptech rotors.
    Veteran Member Four Rings Black3.2's Avatar
    Jun 02 2009
    2017%20S6%2C%202019%20Q7
    Atlanta
    More important question - why go to the dealer for service? At 11k the only thing i would imagine is oil change. a very easy DIY or find an independent Audi shop.
    B6 S4 Cab - Sold
    B7 S4 - Sold, (sadly sold, this was my favorite)
    C6 A6 3.0T - Sold
    B8 S4 - Sold
    2015 SQ5 - Sold
    C7 A6 3.0T - Sold
    2016 SQ5 - Sold
    C7 S6 - Sold
    B9 A5 Sportback - Sold
    C7.5 S6 - Current
    Nov 13 2012
    Phoenix,AZ
    I did the 5K service 1 year ago and its showing up that the 15K service is now due even though I have only 11K miles on it. I can do oil changes myself but after reading all the marketing stuff that goes with the 15K service, i figured I would let them do it...Also, my clear bra is peeling so I need them to fix that as well.
    Quote Originally Posted by yeuchau View Post
    Nov 13 2012
    Phoenix,AZ
    I Would like to know the answer to this as well. I assume it would be real easy to tell that the car has the TCU tune as there is a dead giveaway when you look at the cluster.
    May 08 2004
    NoVA
    I believe the service interval is every 10k or 12 months - he's hitting the 12mos trigger.
    Nov 13 2012
    Phoenix,AZ
    Exactly
    Quote Originally Posted by Brooklyn View Post
