Guys does anyone have a good how to using VCDS to check the injectors are operating as desired. Getting slight misfires detected on cylinder three (3) and have changed the plugs and coil packs. Still pretty rough, particularly when in reverse.
I am thinking of changing the injectors. At the moment the S3 ones are cheaper than the A4 ones. Have I got the correct parts?
I would like to check the fuelling system operation. I have replaced the fuel filter and recently done a carbon clean and HPFP cam follower replacement. If I do need/decide to go ahead with injectors, the S3s are cheaper, I assume I want have any problems nor performance gains doing this, however in the future if I wish to pump the turbo/tune etc, it would be beneficial?
Guide on checking LPFP, rail, HPFP, injectors etc?
Thanks
