    Veteran Member Three Rings B6ayfour's Avatar
    Jun 21 2015
    2014 S4 6MT, 1989 535i5, 1988 ASC Mclaren Mustang 5-speed
    LI, NY
    Parking brake cable replacement
    Alright so as i was replacing my frozen ebrake cable i noticed that both it and the good cable are still looped onto the self adjusting mechanism under the console. What happened is that the assembly ratcheted all the way up from lack of tension and i need to release it. I found one thread talking about this and that there is a special tool, he then made one but the pics are dead so i have no idea what it looks like. If someone could point me in the right direction that would be great.
    14 B8.5 S4 6MT Current Daily
    01.5 B5 S4 6MT SOLD
    04 C5 A6 2.7T S-line SOLD
    02 B6 A4 1.8TQM DG Sport Package SOLD
    Motoza Stage 2, USP front & Cupra lip, S4 rear bumper, 18" BBS CH, OBX exhaust, PSI concepts test pipe, Genesis 380cc injectors, Stratmosphere Hyperboost DV, CX Racing FMIC, Forge TIP, B6 S4 BBK, etc...
    Aug 11 2015
    Norway
    Hey, you're in luck because I fixed this last week. You don't need a special tool, just jam a screwdriver into the little square hole in the middle of the mechanism.
    Basically, what happens then is that the hooks will go all the way forward (sounds like they already did), but it will be possible to pull back the hooks. It's tricky to do if the cables are unhooked, I had to unhook one of the cables at the brake to get it on. You're probably gonna hurt your hands a bit while doing it and expect spending 20 minutes.
    When you are done, refit the cables onto the brakes press into the hole again to make the hooks go as far forward as possible, apply the handbrake 3 times and you're done.
    Jun 21 2015
    LI, NY
    I did try to just jam a pick in there but nothing happened. Is there a specific way to do it? I remember a thread saying to twist 90 degrees but i dont see how thats possible
    01.5 B5 S4 6MT SOLD
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Here ya go: Clicky click® Might find some usable info in here.
    This also may help:
    Jun 21 2015
    LI, NY
    Thanks OG the vid helped a lot. That was the thread i was referring to earlier.
    01.5 B5 S4 6MT SOLD
