Results 1 to 11 of 11
    Nov 06 2009
    London
    Wheels question (forgive me!) 20"
    Hi guys
    New to the B8, picked up a Sprint Blue Avant 2010
    Currently on 19" wheels
    Running 9x20" et30... Am I asking for trouble? Tyre size I can get away with?
    On standard suspension at the moment, possible going KW HAS route later
    Any advice much appreciated
    Current: B8.5 S5. Instagram :- n_i_l_s
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    Here's 20x9.0" ET40 with a 255/30-20 for comparison. (on H&R sport springs)
    Stretched tires and possibly some adjustable control arms would likely allow for an additional 10mm of offset. I'm sure other members here have experience working closer to the specs you have listed.
    Nov 06 2009
    London
    Hmmm
    That's pretty flush!
    Perhaps a little stretch 245/235 will allow the extra clearance
    Mar 21 2015
    Nov 06 2009
    London
    Yes I've seen that and browsed through it but not found my answer hence the post
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    With a 30 offset you might run into clearance issues with the suspension, you may need a 5 mm spacer and 245 series tires.
    Mar 21 2015
    Quote Originally Posted by N11LS_J View Post
    Well thanks, tons of people just post away without looking, kudos to you.
    Nov 06 2009
    London
    Quote Originally Posted by ModItNow View Post
    245 is what I was thinking too
    Adding a 5mm soacer will just bring the wheel out further, making the wheels et25
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Yes but usually with offsets lower than 35 the wheel/tire gets too close to the suspension so the spacer would push it out for clearance.
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    Err...spacers wouldn't make the wheels et25...it would just move the hub point out, but keep the offset amount identical.
    Offset is wheel edge to hub connection, not to the actual hub.
    Active Member Two Rings Sparks's Avatar
    Jan 01 2016
    1994 Mitsubishi Mirage
    Here is my setup, i still have yet to lower it. 20x8.5 et 35 with 245/35 rubbers.
