Page 1 of 3 123 LastLast
Results 1 to 40 of 81
    Veteran Member Four Rings swededA4's Avatar
    Apr 02 2010
    Usually other peoples Audi's
    Greenville,SC
    2002 6 Speed Swap help
    Ok so I also have a 2002 that went from a 5 speed to a 6 speed transmission. Followed this thread and got the speedo working. Guessed and was able to get the reverse lights working. So now to the question problem. How do I get the cruise control to work in 6th gear? Also how do I get the speedometer to keep working while in 6th gear? Which was really fun to find out while going on a road trip. Works fine in first through fifth. It works for a little bit while in 6th. Then it realizes it's not supposed to and drops to 0 mph. So awesome by the way. Cruising down the highway at 80 mph and then boom your going 0. How have you guys resolved this?
    Motoza PODI BAE Parts4Euro
    BAE turbo, 550 injectors, Greddy FMIC, S4 TB,Snow meth kit, Privat Werks 19 X 8.5, Solowerks Coilovers, 034 end links, RS4 rear sway, Deval Splitter, 15% tint, 3" full exhaust with Borla 40357's, JHM trio, PODI Stepper, Recaro's
    Dec 18 2011
    Colorado Springs
    Do you know if the Image on the ECU needs to be flashed to a 6MT? See if Motoza can copy your file to a 6MT ROM to tell the car it has another gear maybe? I'd assume the ECU's are all the same for the manual just with different settings... VCDS recoding maybe?
    '12 GLI EFR 7163 - '16 S3 IE Stage 2
    Dec 25 2004
    Earth
    Sounds like the instrument cluster need coding for the 6spd....
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Aug 17 2015
    '64 VW Type 3 Notch, '66 Type 3 Fastback, '77 Rabbit 2.0L 16v w/ITBs, '84 944, '99 323i
    Evansville, IN
    Quote Originally Posted by B6A4Dave View Post
    The '02 ECU is different from all the rest. If there is a difference in coding, I'm sure it can be done on an '03 (since it's the same ECU as the '04-'05), but I'm not so sure it could be done on an '02.
    BTW, I'm planning on doing a 6 speed swap in my '02 in a few weeks, so this is definitely relevant to my interests.
    Aug 17 2015
    Evansville, IN
    On second thought, the '02 3.0L had a 6 speed available, so there's a good chance that if it is a coding issue the '02 ECU could handle it.
    Aug 03 2014
    WPB, FL
    I've tried changing coding on two different 02 ecus to 6 speed and it doesn't work.
    07 Q7 4.2 S-Line
    02 A4 B6 Avant - Sold
    Senior Member Three Rings MoparFreak69's Avatar
    Jan 31 2015
    2005.5 Audi A4 Avant 2.0T quattro
    Boise Id
    The only option you have is to get an '03 or '04 ECU (ends in either 518 AF OR 518 AK) to replace your 518 F ECU in your car. The cluster doesn't do the gear calculations, that is handled by the ECU.
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    How in the hell does the ecu know what gear your in? When I did the tip to 6 speed conversion I didn't have to recode the ecu. Only thing electrical hooked up to the transmission is the reverse lights. I just removed the tcu and was good to go. PRESS CLUTCH TO START... actually fixed it self.
    Sent from my SM-N910P using Tapatalk
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Jan 31 2015
    Boise Id
    Quote Originally Posted by 19jdog View Post
    Engine RPM vs wheel speed. Easy. If you're doing 7K RPMs at only 25MPH what gear do you figure you're in? Gotta be first.
    Aug 17 2015
    Evansville, IN
    Quote Originally Posted by MoparFreak69 View Post
    I thought there were distinct differences in the '02 ECU that makes it not interchangeable with the '03-up ECU. I know the cluster is also '02 only, so I'm guessing that at the very least they'd have to both be changed. Does anyone have any experience swapping an '03 ECU into an '02?
    Aug 26 2005
    Quote Originally Posted by 16vCorey View Post
    I have not done it but I am very familiar with the wiring diagrams and the '02 uses the same wiring as the '03/'04. The instrument cluster is wired the same as well. The important communications with the ECU and the IC, is via the powertrain CAN buss, so there is no incompatibility that I know of. The difference between the '02 and '03 ECUs is all internal to the '02 ECU.
    Vorsprung durch Technik
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    http://s4wiki.com/wiki/Tuning
    Gear detection
    The ecu computes the gear (gangi) from the quotient N/V out of nmot_w and vfzg_w. To find the current gear, the ecu uses for each possible gear a min and a max quotient to compare the actual N/v against.
    You have to update these quotients in order to map with the present gearbox/wheels. The thresholds are named NVQUOT1O (upper quotient for 1st gear), NVQUOT1U (lower quotient for 1st gear) up to NVQUOT6O, NVQUOT6U for 6th gear.
    NVQUOT1O (0x013BC2)
    NVQUOT1U (0x013BC4)
    NVQUOT2O (0x013BC6)
    NVQUOT2U (0x013BC8)
    NVQUOT3O (0x013BCA)
    NVQUOT3U (0x013BCC)
    NVQUOT4O (0x013BCE)
    NVQUOT4U (0x013BD0)
    NVQUOT5O (0x013BD2)
    NVQUOT5U (0x013BD4)
    NVQUOT6O (0x013BD6)
    NVQUOT6U (0x013BD8)
    It seems like the ECU is looking for a certain engine RPM VS speed... If its too far off - no cruise. Other cars with the M7.5 have a similar problem if a taller fifth gear is installed.
    http://www.ecuconnections.com/forum/...37a7c8e#p95264
    You will have to register to get to the site.
    Mar 28 2015
    I have not recoded my 2003 1.8T to know it has a six speed. For sure, my cruise control does not work in sixth. If I have time, I will give it a try after work today.
    Aug 03 2014
    WPB, FL
    This. All of it.
    Quote Originally Posted by Kevin C View Post
    07 Q7 4.2 S-Line
    Aug 17 2015
    Evansville, IN
    Can someone translate that into English? I have Vag-Com, but I'm not super familiar with coding.
    Aug 03 2014
    WPB, FL
    What Kevin is saying is this cannot be done with VCDS/Vag-com. You will need a program to modify the ECU file, like Nefmoto can.
    Basically there are values stored in the ECU that say, if vehicle speed is X and rpm is Y, then you are in gear Z. For example, if you are at 10 mph and 2500 rpm, the ECU checks the table and looks at the lower and upper limits given to figure out what gear you are in.
    I never made it this far as I couldn't get Nefmoto to read my ECU file without removing the ECU and rigging a bench setup to read/write. I got a spare ECU and was putting together a bench setup but sold the car before I could see this through.
    You will have to read the ECU, find the quotients he listed, and update 5th and 6th to allow for cruise. What wasn't clear to me is if there actually will be a quotient in the ECU file for 6th gear since that transmission was never offered. I don't know if the 1.8T and 3.0 (which had a 01E 6 speed) use the same ECU just different coding, or have different ECU's all together.
    Most likely the quotient will be there, but the values will be 0. If that is the case, just pop in a range (upper and lower) and see what happens.
    07 Q7 4.2 S-Line
    Aug 26 2005
    None of that is required to recode a 518 AK ECU to 6 speed.
    Aug 03 2014
    WPB, FL
    2002 ECU is 518 F. I personally tried to recode 2 different ecus with 2 different VCDS cables and neither one would take the coding
    07 Q7 4.2 S-Line
    Veteran Member Four Rings Wet0willy01's Avatar
    Nov 17 2008
    05 A4 USP, 00 S4, 01 A4, 16 A3
    I have a spare pair of ecus Ben. I was going to loan one out to Matt but you can fight over it. My Uni630 ecu came back and 6th gear CC never worked. I'm one of the many who got duped there.
    -Andrew
    2005 Dolphin Grey Ultra Sport
    630AWHP HTA3582R 1.8L 93+ Meth
    Before camber and tire stretch, there was horsepower and performance.
    Mar 28 2015
    What six speed did you use?
    Aug 26 2005
    Quote Originally Posted by Airflite40 View Post
    Right. The '02 ECU won't accept coding for a 6 speed because there was no 6 speed trans available from the factory in '02. An '04 518 AK ECU will recode to 6 speed for sure.
    Jan 31 2015
    Boise Id
    All ME7.5 ECUs are pinned the same. I can run my car off the ECU from my GTI however the fan is controlled differently in the GTI so the coding to control the B6 fans is not present. The only real difference is processor speed. Newer versions run a faster clock speed to handle calculations faster and more efficient for better emissions.
    The 3.0 uses a different version of Motronic that has its own completely different set of coding and maps. That's why you can't code a 1.8t to a 6 speed in '02 because no such coding value exists for that ECU software version.
    Aug 26 2005
    For ECUs capable of being coded for a 6 speed trans, the software code shown above as applicable for the 6 speed trans is already programed into the ECU, and enabled when the ECU is coded for 6 speed.
    May 24 2008
    cornish,me
    Would a 2004 1.8 6 spd manual ecu work in the 2002 or is that just feasible.
    Aug 26 2005
    Quote Originally Posted by refueler View Post
    Yes, provided the immo is adapted to the IC.
    Mar 28 2015
    Quote Originally Posted by Spike00513 View Post
    I went from automatic to 6spd. Cruise control works in 6th.
    Was: 01V 5HP19FLA. ID-code: GBJ from '04 3L.
    Now: 02X 6spd quattro from '04 3L.
    "Deleted" the TCU. AKA, underneath the ECU there is a "second" one. Simply unplugged and removed it.
    During swap, recoded ABS, cluster, and ECU to 6spd.
    However, all 3.0L model years were available with 6spd manual too. '02-'03 was 01E-type, a type which Audi used in many cars you all know including 2.7T's but with part variances I guess.
    '04-'05 was 02X-type.
    Not sure of the ECU PN.
    I was thinking that its very possible that the 2002 ECU had the entry table for all six gears. The variable is what ratio sixth gear you have and does it match up to what the ECU expects. That's why I was curious what code transmissions people have been using.
    Mar 28 2015
    Went TO GJV.
    GJV is 3L 02X.
    GJW is 1.8T 02X.
    Practically the same, aside from a different FD and 4/5/6 ratio.
    I may be wrong though.
    '04-'05 like I said. If it was PRE '04, then 1.8T got an 01A-type 5spd, but 3.0L got 01E-type.
    Keyword is "Type". Type, is not the same as code. As you may know.
    Type: 0A3, 01X, 02X, 01E, 01A, 01V, etc.
    Codes: GJV, GJW, etc.
    I'm lost here. I don't think my ECU would care if I switched my GJV for a GJW, whose 6th is probably lower. Or an 0A3 or 01E, such as an FYF-code from an early 3L.
    I guess I need to re-read the thread. Admittedly, I'm a noob to this stuff.
    I'm going to claim any posteriori knowledge (AKA, I'm also figuring it out as I go). For the 2004 ECU to work in sixth, the final drive probably needs to match the one used in 2004 (0.685x 4.11= 2.815 02X GJW trans). If you have an 02X GVE (2.0T, B7) the final is 2.56, the ratio (gangi) might be too far off for OD to work. I didn't find anyone that has tested this... Basicly be aware there are a couple of factors.
    Aug 26 2005
    IF the ECU accepts coding for a 6 speed trans, I don't think it matters what the specific gear ratios are. The trans soft coding values implemented do not differentiate between trans ID codes.
    Aug 26 2005
    I don't think the '02 ECU has the maps for a 6 speed since a six speed was not available with a 1.8T in '02. That is why the '02 1.8T ECU won't accept coding for a 6 speed trans.
    See linked post #24:http://www.audizine.com/forum/showth...1#post11182161
    Mar 28 2015
    That's the part I'm not sure about. The other thing, is even if there is only five mapping slots for the gear ratio, what would stop someone from skipping first and recoding the rest to work with the top five gears? I never use cruise in first!
    Also, my understanding is there was a 1.8t six speed in 2002, but it was not imported to the US. http://www.automobile-catalog.com/auta_details1.php Does that help us ? No clue.. At least yet.
    Apr 02 2010
    Greenville,SC
    I swapped the transmission, drive shaft and rear diff from a early model 04 1.8t quattro. Dave (motoza) has been trying to adjust the parameters of 5th gear. So while I am in 6th gear it still thinking I am in 5th. With that said and everything that I have read here. It appears my only option is to swap ECU's. I can get the ECU from the audi I got the transmission from. But I would need to put an ecu back in it's place. So I can put the ecu from the 04 in mine but can put my ecu back in it's place?
    Aug 26 2005
    Quote Originally Posted by swededA4 View Post
    You can do that, the donor A4 is not being driven, right? The immo would need to be adapted for both ECU after the swap, so that both engines will run, but I am not sure if the '04 A4 would accept the '02 ECU.
    If the '04 A4 donor car does not need to run, then it doesn't matter if the '02 ECU works in the '04 or not.
    You might want to consider getting the instruments from the '04 also and getting it virginized, then you can just adapt the keys to the '04 IC since the IC and ECU immo IDs should already match.
    Apr 02 2010
    Greenville,SC
    Not currently. But he will want to drive it again. Eventually. Which is why I ask if my 02 ECU will go into it.
    Sent from my Nexus 6 using Tapatalk
    Aug 26 2005
    I don't know of any reason the '02 ECU won't work in the '04 A4, especially if the instruments are swapped also.
    It would probably be a lot easier to just buy another '04 ECU.
    Apr 02 2010
    Greenville,SC
    Isn't there something about the fan control module that is different?
    Aug 26 2005
    Most of the Euro of ROW ECUs have specific part number suffixes. Frequently the NA specific part number suffixes won't accept recoding to Euro or ROW.
    Aug 26 2005
    Not that I know of. All '02>'05 AMB fan control modules receive a PWM control signal from the ECU, and are wired the same.
    Mar 28 2015
    FYI, my 2003 would not accept coding for a six speed. I tried Also, from what I have read, the basic ECU hardware is compatible over several different models and BIN files can be used to program them into whatever part number you would like.
    Jan 31 2015
    Boise Id
    False. The 02's have a different processor speed and won't accept a BIN from any other version. The 03's and up can be cross flashed, but require EEPROM BINs that match the main BIN you are flashing to the ECU or fits will be thrown by the car, ask me how I know.
    Mar 28 2015
    True... That said, I didn't mention any specific years.
