Results 1 to 9 of 9
    Established Member Two Rings dwbunks's Avatar
    Jun 23 2014
    Ottawa
    Transmission popping out of 3rd and 4th gear? Worth Getting?
    I have the opportunity to pickup an 01.5 s4 with 220k km, timing belt and turbos done at 175k, 6 speed santorin and black leather. I would be getting the car dirt cheap.
    "The engine has a small coolant leak from a frost plug and tranny needs rebuild or replaced"
    He says it pops out of 3rd and 4th gear if you take your hand off of the shifter.
    Anyone have any insight on what this could be?
    The car has a JHM short shifter, forge dv valves, borla catback and is "lowered on springs"
    Overall it looks ok, is it worth taking the risk on it?
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    If you can get it for less than 1000 bucks id say you did well.
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    Time to rebuild the trans most likely the syncros are going out.
    Jun 23 2014
    Ottawa
    Quote Originally Posted by a4kamila6 View Post
    He's unloading it for $1500, I might try and get it for closer to 1k.
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    Quote Originally Posted by dwbunks View Post
    That's not too bad either.
    Sep 30 2015
    Quote Originally Posted by MikeyB3 View Post
    Yea if the car is all there, cosmetically in good shape, I think thats worth it also.
    I have a santorin blue a4, by far my favorite color found on these cars. I have a black a6 also but the santorin is where its at. When washed, polished and waxed, god damn that paint looks good.
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    Not a bad deal as long as there isn't a
    laundry list of other shit wrong with it.
    Dec 10 2013
    Borden, Ontario, Canada
    That's a steal. You'll be ahead either way
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Nov 14 2013
    ^^^ Agreed worth more in parts alone.
