Results 1 to 24 of 24
    Oct 02 2006
    Wadsworth,OH
    :: ECS Tuning :: NEW!! ECS Flush Fit Kit | B9 A4
    The German TUV (Technical Inspection Association) has determined that in several European countries the clearance between fender and tire must be adequate to accommodate snow chains when safety requires.
    In North America, where no such law exists, A4 owners have the option of restoring Audi's original intention of providing a focused race-bred machine by widening their car's stance, improving road-holding and performance aesthetics.
    Improve your stance appeal with the in-house fit/tested hubcentric 10mm front / 12.5mm rear ECS spacers & appropriate-length bolts setup.
    Kit includes:
    • Front 10mm Spacers - 2
    • Rear 12.5mm Spacer - 2
    • 38mm Black Ball Seat Wheel Bolts - 10
    • 40mm Black Ball Seat Wheel Bolts - 10
    Get that flush fitment
    Fits:
    Audi B9 A4 '16+
    *This kit is designed to work with the factory 18" wheels that are 18"x8" ET40*
    Jason
    Established Member Two Rings Mpower2170's Avatar
    Sep 18 2015
    NoVA
    Kit includes:
    Fits:
    Audi B9 A4 '16+
    Jason
    Do you have any pictures of the A4 fitted with 12.5mm front and 15mm rear OR 15mm front and 17.5mm rear?
    Instagram: @PhilippBirk
    2018 A5 | P+ | Glacier White | Sport Pkg | Tech Pkg | CF Mirror Caps & CF Lip Spoiler
    2017 SQ5 | P+ | Mythos Black | Tech Pkg| Red Brake Calipers | Black Optics Pkg| Chipwerke Pro tune
    2017 A4 | P+ | Mythos Black | Sport Pkg| Tech Pkg| 1st Ed. Pkg| Black Headliner | Chipwerke Pro tune
    2015 A5 | P+ | Ibis White | Sport+ Pkg| B&O Sound | Black Headliner | Smoked Taillights
    Oct 02 2006
    Wadsworth,OH
    We do not.
    Jason
    Sep 18 2015
    NoVA
    We do not.
    Jason
    Would you think either / both option would work okay with 19" wheels. Contemplating between the three sizes before I commit to an order.
    Oct 02 2006
    Wadsworth,OH
    I would imagine that would be too much. Our kit gives the factory wheels a flush fit which is even with the fenders. Going with even thicker spacers would likely cause the wheels to poke out past the fenders. Which could definitely cause some rubbing.
    Jason
    Veteran Member Three Rings casuso's Avatar
    Sep 19 2006
    Mexico
    Jason, I have a relative traveling next weekend to San Diego, do you think if I order today it can be delivered before next Sunday?
    A4 B9 Tango Red Sline FWD
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Quote Originally Posted by Mpower2170 View Post
    Knowing that ECS' kit makes the 18" wheels flush, it should be easy to figure out optimal spacers for yours if you just compare the effective offsets of the two OEM wheels.
    I can look in a second.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Senior Member Two Rings dbuxton13's Avatar
    Apr 20 2016
    Germany
    Aren't 19" wheels the same width as 18"?
    Also, I really want these, but way too early... want to put them on a future S4! (would they be the same as A4 ya'think?)
    B9 S4
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by casuso View Post
    To San Diego? Our Typical transit time is 4 business days to that area. Assuming you have ordered with us prior so you can ship to a different location than the billing address.
    Jason
    Sep 19 2006
    Mexico
    Jason
    I am located in Mexico, so a relative in San Diego is as close as I can get from you
    Will place order ASAP.
    Feb 25 2014
    Texas
    What size kit would make the 19" Audi wheels flush? I will order now if you have an answer...and hopefully pics!
    Mickey (AKA: AudiS4B8)
    Instagram: ze_nardo6
    10.65 @ 129mph
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by AudiS4B8 View Post
    I don't know of the top of my head. But seeing that the 19s are 8.5in width it will change how our flush kit would fit on those wheels.
    The best way to understand which size spacer you need, is to simply measure from the top outside edge of your tire to the inner lip of your fender. This will give you the best idea on how much size you have to work with, and to decide on how much your wheels need spaced.
    Once you know that let us know and I will be able to recommend which size will be the best fit for your application.
    Here is a diagram that might help as well.
    - - - Updated - - -
    Sounds good!
    Jason
    Apr 20 2016
    Germany
    I guess I'm having difficulty believing or understanding that Audi would provide options for 18 and 19 inch wheels that create a different outcome on the spacing from wheel to fender in any direction. The circumference and diameter of the tire have to be the same for wheel speed to measure properly, right? Are 19in wheels somehow wider than 18in? By how much? They don't look any different on the configurator program. Honest question here.
    B9 S4
    Oct 02 2006
    Wadsworth,OH
    When I looked up 19s for B9 A4 they gave the spec 19X8.5 ET40
    This is wider than the 18X8 by half an inch.
    Though it is wider this is the reason they make such a variety of tire sizes. It would be no different than if your vehicle came with 18's and you want to run aftermarket 19's you simply would get the proper size tire that is likely a series smaller to accommodate the added inch in height.
    Jason
    Dec 10 2011
    CLT | MKE
    Here are the OEM wheel specs I found for the B9.
    17x7.5 ET38
    18x8 ET40
    19x8.5 ET40
    This means the 19" will "poke" 6mm more as compared to the the OEM 18" from the factory. Thus, after adjusting according to ECS' 18" flush spacer sizes, you would want 4mm front, and 6.5mm in rear. Probably easier to find 5mm F and 7mm R.
    -Hayden
    Oct 02 2006
    Wadsworth,OH
    Jason
    Veteran Member Four Rings Jet Jockey's Avatar
    Jun 17 2004
    2017 B9 A4 Quattro/DSG/Technik/S-Line... 2004 B6 A4 1.8T Quattro race car
    Montreal, Canada.
    Jason,
    Do you guys have a stud conversion kit for this car? I hate bolts!
    Established Member Two Rings Da_Big_Sweed's Avatar
    Apr 14 2017
    Socal
    Stock 19 in. rims with 15mm spacers and emmanuele design springs
    Sent from my SM-G920V using Audizine mobile app
    Veteran Member Four Rings hyperspeed's Avatar
    Feb 13 2004
    Chino Hills, CA
    nice! got any more pics from side profile? are the S4 springs the same as the A4 ones?
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by Jet Jockey View Post
    Jason,
    We do!
    Check out the link below.
    Click HERE
    OEM wheels are ball seat FYI.
    Jason
    Veteran Member Four Rings XxSullyxX123's Avatar
    Mar 04 2015
    2020 Jeep Unlimited Wrangler Rubicon Recon, 2023 Honda Pilot Elite
    Somers, NY, USA
    Quote Originally Posted by Da_Big_Sweed View Post
    Do you have more pictures of your car? This B9 platform is looking better and better already!
    2016 S4 P+ | Mythos Black | DSG | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | B&O | Carbon Inlays | Supercharged Badges ||| - SOLD
    2015 S4 P+ | Monsoon Grey | 6MT | Blk Optic Pkg | Blk Nappa Leather | Tech Pkg | Supercharged Badges | AudiGuard ||| - SOLD
    Apr 14 2017
    Socal
    Quote Originally Posted by XxSullyxX123 View Post
    Before the spacers and blacked out reflectors
    Apr 14 2017
    Socal
    Quote Originally Posted by hyperspeed View Post
    I'm not sure... you would have to ask emmanuele designs..they did all the heavy thinking lol
    Mar 04 2015
    Somers, NY, USA
    Looks awesome thanks!
